Question about Sansui TVS2750 27"
My jensen tv has no color when hooked up to playstation2 (modelts2750j)
Tv has no color when hooked up to playstation3
Re: my jensen tv has no color when hooked up to playstation2 (modelts2750j) - Sansui TVS2750 27" Standard (CRT) Televisions
Same with my ps2
Posted on Sep 03, 2008
0 characters
3 Points
Jensen color tv model ts2750j volume is maxed out but stll can't hear it
Check its speaker. If it is found OK, check and replace damaged component/s in the audio output circuit inside.
Oct 04, 2012 | Jensen TS2750J TV
Our Jensen has no color. We have picture and sound, but in black and white. The display settings on the screen are in color. Anything I can do? The model is TS2750J. It's only 2 years old!
There are different types of color settings and systems - NTSC, PAL and SECAM. Are you sure the correct one is selected ? If yes then the problem is in the decoder and must be replaced since the chip cannot be fixed. This is a job for a pro.
Jun 27, 2010 | Jensen Q2749J 27" TV
DVD plugged into red, white and green(Yellow) TV imputs, results
Yeah no color coz its black and white. Color coding commonly yellow wire for video, red and white wire for audio. It should also be from DVD to TV, video out and audio out going to video in and audio in. And switch the TV to play video and the audio inputted. Maybe TV/Video Switch or button.
Hope it helps
Apr 06, 2009 | Jensen TS2750J TV
Locked tv
this happen to me a couple times before if remember you need the orginal remote then hold down menu and another button sorry i dont remember which one sorry hope this can help
Mar 10, 2009 | Jensen TS2750J TV
TV in 5th Wheel Camper does not work when hooked up to cable
is there a setting to change to CATV vs off air ?
Jan 07, 2009 | Jensen TS2050J 20" TV
Password for tv function
try unplugging it for about 3 days.
Mar 02, 2008 | Toshiba 19A26 19" TV
Jensen q2749j
if u know about fixing appliances, u may open it and check the CRT Board for looose solder on the three color driver transistor or the IC Pins that's responsible for the color. simply soldering the pins and components nearby may fixed the problem. More serious cases may need a true technician.
May 20, 2007 | Jensen Q2749J 27" TV
Sansui TVS2750 27" Logo
Top Sansui Standard (CRT) Televisions Experts
Level 1 Expert
rugby prop
Are you a Sansui Standard (CRT) Television Expert? Answer questions, earn points and help others
