Question about Speed SV800 DV Digital Camcorder
Sound but no picture
. unable to play video. Sounds ok but no picture. Same on all video players. thanks
  • 3 more comments
  • ian6893 Aug 01, 2009
    I HAVE SENT COPY OF FILE TO COLLEAGUE AND IT PLAYS FINE ON THEIR POOTER. IF I DOWNLOAD AVS CONVERTER IT WILL CONVERT TO ANOTHER FORMAT AND WORK OK SOUND AND PICTURE. JUST WONT SHOW PICTURE WHEN PLAYING ON MY MACHINE. SOUND IS OK JUST WHITE SCREEN.
    EVERYTHING WORKS OK ON CAM CORDER. EVEN WHEN I LOAD DIRECT FROM CARD ITS THE SAME. IT DOWNLOADS INTO .MOV FILE . VIEWER OPENS IT OK BUT JUST GET WHITE SCREEN .
  • ian6893 Aug 02, 2009
    we make progress. I have installed codec which took 3 attempts but now I have video picture but no sound. Im using windows media. I have sound with using other files but not when playing these videos. I did have sound before but then no picture.
    Tried VLC and all is good. Thanks for you help.
    yep sorted out my problem so no longer sucidal. Thankyou
This is a codec issue on your computer. Please install the following depending on which edition of Windows your computer is running:
  • Windows XP, download this
  • Windows Vista, download this
Install the software ticking all options if asked. After installation, restart the computer (this is important).
Now try playing the video. If it doesn't play, right-click on the video file, choose Open with...
Open it with Windows Media Player. Does it play in Windows Media Player? If not, please download QuickTime Alternative here, install it, and try playing it in Windows Media Player again, does it play?
If still not, finally, download VLC Player here, install, and attempt playing the video with VLC Player.
Please try the above all in order until you get to a point where it does work.
Best of luck! Let me know if you need further help.
Posted on Aug 01, 2009
  • Speed Master
  • 19,396 Answers
If the Video Plays on LCD display, then try resetting the camera to factory settings by removing and putting back the battery.
The recorder will use PAL or NTSC, depending on your region,ensure that the camcorder setting is the same as the recorder.
Also ensure that camera is set to playback not to record when connecting to recorder.
If still no luck and video plays on LCD display, or on different camera, then the connectors on camera may be defective.
If instead video does not even play on camcorder, then the unit is faulty, and it can be a faulty CCD sensor, lens problem or control board/connectors problem.
In that case the camcorder will need repair service.
  • Ginko
    Ginko Aug 01, 2009
    If the tapes play fine on different camcorder, then head is recording fine. Try playing images from memory card, if you can see the picture, then problem is related to camcorder heads on playback. Not a misalignment issue, since the tape works on different camcorders.
    It can also be a digital processing problem.
    If it does not display pictures on SD card, then there is something wrong with main control board, or with the firmware.
    Naturally I assume the LCD works when you are recording.
    Let me know.
Sony kvj21mf1ak
It sounds like either the TV or the device is trying to do S video instead of composite video.
see if you can change the output type of the media player and make sure that the TV input is not set to S Video.
Nov 19, 2013 | Cell Phones
My usb has sound but no picture I have a AWA DP747 player
hii,
It seems your video has been corrupted, so you need to have repair software, which can regenerate the desired file. If you are unable to find such software you can ask me.
Jan 29, 2013 | Televison & Video
Sudden loss of picture, sound comes though ok
It sounds like the exact same problem that my son recently created. The only solution I've determined is to reset the player to it's default settings. Although it took a little while (since the video display was not present), I finally found the right combination of buttons to push on the remote and now the problem is fixed. Insert a disk, then push the following buttons: Stop, Stop, System/Menu, >, >, >, v, v, v, v, v, >, OK
After the above sequence of buttons, the main player screen should reappear on the tv.
Croce23
Jan 04, 2009 | Philips DVD727 DVD Player
Will play sound but no picture
1.check your video cable between DVD and TV.
2.in back of dvd one yellow socket only for video out others for some other purpose.
3.open tray conditon .-go to system menu on Remote -go to general set up page-video set up -and switch of .progressive -in OFF-mode.
then try it for video play back
4 if not ok replace the video decoder ic.
Nov 12, 2008 | Philips DVP642 DVD Player
80GB I Pod with video capability
hardware failure you need a new ipos it sounds like call apple to make sure
May 20, 2008 | Apple iPod MA446LL/A MP3 Player
DVD playback no playback
Sounds like the scart lead is not in straight. Scart connectors have the audio pins at one end, and the video pins at the other. If the lead isn't in straight then you often get sound and no picture and vice versa.
Check the connection by pushing the scart lead in securely. (Both DVD and TV end of the lead)
Failing that could be a dodgy lead.
Mar 17, 2008 | Philips DVDR3380/05 DVD Recorder
Dvd video player model no DVP3120 unable to get player to play on tv setting AV1 at all but on tv setting AV2 player plays dvd`s but picture only no sound. it is connected using a Scart lead.
through a process of elimimation I identified the problem as a faulty scart lead
replaced lead and all was okey dokey
thanks for advice posted
colin the cat
Jan 22, 2008 | Televison & Video
No picture
Sounds really broken. Unless you can find a replacement DVD drive for low money , you may have to junk it.
Dec 12, 2007 | Sanyo DVW-7000 DVD Player/VCR
No picture
It sounds like the backlight in your player may have failed. You will have to take the unit to a qualified technician for repair, because there are no user serviceable parts inside. I wish I could give you better news.
Jul 19, 2007 | Zenith DVP615 Portable DVD Player
Speed SV800 DV Digital Camcorder Logo
48 people viewed this question
Top Speed Video Cameras Experts
Are you a Speed Video Camera Expert? Answer questions, earn points and help others
