Question about ViewSonic N3735W 37 in. LCD TV
My 32" LCD tv just stopped working. The power light won't come on. What can I do?
My tv won't come on the green power light just flashes?
push and hold the power button, i did yhat to mine and it now works,also if it comes on reset the tv
Dec 12, 2012 | Sharp LC-32SB24U 32 in. LCD TV
Tv wont come on
make sure it's fully plugged in. if it still won't work, then it's your wall plug or your tv
Aug 03, 2012 | Protron PLTV3250 32 in. LCD Television
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
I have a sharp lcd 32 inch it stopped working, it won't turn on.
Try to check the main line and if its ok proceed to the power chord then to transformer or the fuse and you look it they are fine look for a technician to check your tv.Choose a better technician near from your place.
Nov 06, 2011 | Sharp Aquos LC-C3234U 32 in. LCD TV
Tv won't turn on green light blinks
First check the power supply for incorrect voltages, and bad capacitors in an around the output side of the power supply. You may have swollen caps inthe power supply area that needs replacing.
Aug 24, 2011 | Sharp LC-32SB24U 32 in. LCD TV
32 LCD, Shuts off, power light flashes 7 times. Never stops. Will not turn back on unless I unplug. Works for a few mins and shuts off again.
Power supply board is dead.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 22, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
32" Dynex No Power, Power on/off light will not light up
Check the power supply module first for blown fuse, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 12, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Lcd not turning on
May i know is it the power led light blinking or just steady?
Jul 20, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sharp aquios 32"
unplug the tv from the power outlet, wait until the light stops flashing then plug it back in. works for me.
the flashing light means that your tv needs to be serviced, if its still under warranty you shouldnt have to pay for this.
-w
Nov 17, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
ViewSonic N3735W 37 in. LCD TV Logo
155 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
