Question about GE Advantium 120 Convection/Microwave Oven
Replacing door handle on GE advantium
I've got the top screw exposed but can;t figure out how to expose the bottem screw to replace the handle on the door
  • GE Master
  • 9,085 Answers
We have the service / repair manual for this model and have uploaded it to our site here (or here) for free download to help you.
You can find helpful exploded view diagrams and order parts & accessories by entering your full model number here.
Posted on Aug 01, 2009
How to replace door handle
open door
lift up seal of door to expose srews then remove
sperate seal and inside door glass
that exposes screws for the handel remove and replace
Jun 30, 2012 | GE JVM1330BW/WW Microwave Oven
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
Mmi have a ge advantiun x20 model SCA1001FSS01 THE HNDLE IS BROKEN OFF HOW DO i REPLACE THIS pafife@yahoo.com
HELLO.
THE SOLUTION ON HOW TO REPLACE THE BROKEN HANDLE
THINGS NEEDED.
Phillips screwdriver.
Thin, flat-head screwdriver.
Putty knife.
Replacement microwave door handle.
1 Examine the inside of the door. The handles of some early GE Spacemaker microwave models were attached after the two inner door panels were assembled to the outer door. If you see two recessed screws opposite the handle attaching points, undo them with a Phillips screwdriver and remove the handle. If not, go to the next step.
2 Insert the blade of a thin, flat-head screwdriver into the top, outer corner of the door, between the plastic inner frame and the outer door. Gently pry the inner frame out and slip a putty knife into the exposed opening on top of the door. Slide the putty knife toward the hinges to free the top of the inner frame; repeat on the front and bottom edges of the door and lift the inner frame out to expose a second metal inner frame.
3 Insert a thin, flat-head screwdriver into each of the small square openings on the top and bottom of the inner metal frame, starting at the handle end of the door. Undo the attaching clips by gently levering the inner door away, using the rim of the outer door as a fulcrum. Move the inner door away from the outer door on its hinges.
4 Remove the glass from the outer door. Undo the two screws holding the handle to the outer door with a Phillips screwdriver. Screw the replacement handle onto the door and tighten securely.
5 Replace the glass panel and reassemble the door by snapping the two inner frames back in place.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I oderered, & received a new handel, to replace the broken one.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
It will give you safety info and step by step help in disassembly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 25, 2009 | GE Advantium 120 Convection/Microwave Oven
Replace handle on adeantium sca1001fss01
you have to take the door off and pop out the plastic molding around interior of door. You can do this by sliding a screwdriver around the edge until you can get your fingers in. Be careful because there are some small plastic tabs that will break very easily. Next, remove screws on the backing of the door. There are similar tabs holding the backing on even after the screws are removed. I used a pair of insulated pliers and used the handle to pry the tabs back. Be careful because the tabs will break easily. Then the screw handle is exposed. Pretty easy huh?!!!! I just comleted this process and am looking for a handle. I am sure I will have to super glue some areas since I broke the tabs off.
Good luck
Jun 01, 2009 | GE Advantium 120 Convection/Microwave Oven
The door handle on my GE Profile ADvantium 120 Microwave is broke
appliancepartspros.com. part number AP3187809 $56.40 plus shipping
Apr 27, 2009 | GE Advantium SCA1001SS Convection /...
Light bulb in oven went out
Remove the top grill by removing two screws in the top. Pull the top of the grill out towards you as the bottom has pegs on it. About 6 inches from the left is metal cover that you just squeeze with your finger tips to remove. This exposes the bulb.
Mar 28, 2009 | GE Advantium 120 Convection/Microwave Oven
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
Mar 18, 2008 | GE Advantium SCA1000H Convection /...
GE Advantium 120 door latch repair
Does the model you have have the vent that comes out at you. If so you need to take the screws out of the top front. Then after they are out not to hard slide the vent to the left give a little force. the vent comes off then you can access the screw that holds in the board
Jul 03, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
159 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
