Question about Kodak EasyShare P850 Digital Camera
Have the 850...2 good batteries (each at 4.22V)..the camera does not come on...no screen light...just a very small clunk sound when switching the power on
    President:
  • 2,761 Answers
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
Samsung galaxy ace 2 gt 18160
this sounds like you may have a short from the battery to the board.
check the contacts on the phone at the battery to make sure they are not clogged or have any mark that may be causing them to not get a good contact from the battery.
Aug 14, 2014 | Sony UNLOCKED Samsung Galaxy Ace 2 II X...
Car won't start. have power but no ignition I can turn key, all lights come on as normal, but usual ignition sound or anything.....just small clunk.
Sorry, this sounds like a bad battery, pull the battery and take it to your local auto parts store. They will check your car battery for free.
Oct 01, 2011 | Cars & Trucks
When we try to start the car the head lights and interior lights flicker and there is a clunking sound instead of the normal sound of the starter motor turning over?
It might be the battery Or starter, But try to jump it and if it start then you need a battery and if not, Well your started is going bad . Hope its the battery
Good luck
Dec 05, 2010 | 2005 Ford Freestar
2006 Dodge Caravan engine will not turn over
i know you have checked everything .chech 1solinoid on top of starter.2netural wire from battery to starter.if this fails check small red wire from ign to solinoid.[small].adrian,,,
Jul 26, 2010 | 2006 Dodge Grand Caravan
1995 volvo 850 turbo wagon will not start all of a
You can check 2 things. 1., have someone in the car to turn the key to the start position. Tap the starter with a small hammer and see if it cranks. If it does, replace the starter. 2., have the battery tested as well as the connections to the battery. Corrosion builds and can cause heavy resistance to heavy loads(like starting). These are the 2 most likely causes. Let me know if you need further assistance.
Jul 22, 2010 | 1995 Volvo 850
URGENT PLEEEEEEEAAAASE
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
regards,
Luwangula
Sep 16, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
E-850 Digital Camera does not operate after turning on button
Was it impacted in some way or was it exposed to sand, water, or dirt?
Any of these can seriously damage the lens system.
This camera probably needs to have repairs.
Aug 01, 2009 | General Electric E850 Digital Camera
The cassette or hub "clunks" on my mountain bike
it sounds like the barrings your going to have to bring it to a shop or buy a new wheel
May 03, 2009 | Sram 850 8 Speed Cassette 11-32t Mountain...
Broken Battery Door
I have the same hp 850, No way to fix it, So to hold the Battery Door Down, I Drill'ed a small hole through the top. & through the case
where, the camera latch Broke, & do it Real Slow..... Put a Sheetmetal Screw in the hole i drilled & it Work's Find. Just do it SLOW<<<<<<<< Good Luck & it's up to You What size to use
So Think it Over before you Try it....Slow slow slow, & the right size Drillbit,screw, & turn it in Slow.. P.S. It was do that! or $500
Down the Drain, Good Luck, The Wizard
Dec 15, 2007 | HP Photosmart 850 Digital Camera
Kodak EasyShare P850 Digital Camera Logo
99 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
