Question about Nikon Coolpix 4600 Digital Camera
When turned on says memory card protected write
When turned on says 'memory card protected write only' and won't let me delete pictures
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 09, 2010
  • rmwilliam946 Dec 25, 2010
    When I slide the switch it still says memory card is write protected
  • kakima Dec 25, 2010
    What happens with a different card? If you're lucky you just have a bad card. If you're unlucky then the camera may need service.
5 Suggested Answers
SOURCE: Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Posted on Jun 10, 2007
  • 41 Answers
SOURCE: memory card
From your description it sounds like your card is full. Are you able to download to your computer? If you are able to do that then try deleting individual photos on the card using the Computer to do so. If you can achieve that then try to Re-format the card back in your Camera. Hope this helps you.
Posted on Apr 28, 2008
fblock
  • 289 Answers
SOURCE: memory card is write protected
Take your memory card out of the camera and switch the position of the little "lock" tab. That should fix it and you can start saving images.
Posted on Apr 27, 2009
SOURCE: my Coolplix L18 wont let me do nothing
Hi
Take the memory card out of the camera.
You will see a small switch on the card (it is the lock switch)
Slide it to the opposite side and there you go!
It's easy to accidentally lock your card without even knowing it.
lol my mom just had this exact same problem and it was driving her crazy (she too didn't realize the card had a physical lock switch)
Have funn,
Bye
Posted on Jul 12, 2009
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
Sd card trouble
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 29, 2011 | FUJIFILM CD-R Storage Media
My nikon coolpix L20/L19 won't let me delete some pictures it reads write protection. How can i fix it?
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 04, 2011 | Cameras
Camera says memory card is write protected. How can I delete pictures on the card and take new ones?
write protection lock is turned on,, turn it off this maybe 1. a switch located in the camera 2. on off option in the camera menu else plug the camera to memory card reader to delete or format the chip :)
Dec 15, 2010 | Nikon COOLPIX S51 Digital Camera
Canon PowerShot SX20 IS Digital Camera keeps giving me a memory card error. The memory card is a 4gig PNY memory card (lower budget)
Make sure the slide switch on the side of the card is unlocked. Your camera may just want you to format the card in the camera. Download any pics from it first using a card reader if necessary.
Jun 22, 2010 | Canon PowerShot SX20 IS Digital Camera
Need to delete protected pictures
Try to remove first the memory card of your camera. After you remove the card you can see a small button at the side of the memory card. Just slide the small button to unprotected. Insert your memory card back to your camera and try to delete pictures.
Apr 25, 2010 | Kodak Easyshare M753 Slim Digital Camera
I downloaded some pictures to my school computer and now my camera won't take any pictures. Message is Memory card write protected.
If that doesn't work, try another card.
Feb 26, 2010 | Nikon Coolpix 4500 Digital Camera
Why is my memory card write protected
Hello there,
You cannot delete pictures if the memory card inside your camera is "Write Protecte". What you need to do to unprotect it is to turn off the camera and take out your memory card. You will find a small 'tab' that might be pulled up or down. If it is pulled down, you can slide it up or vice versa. Put it back inside the camera and start deleting pictures.
Hope this helps you. Good luck!
Oct 02, 2009 | Nikon Coolpix 4500 Digital Camera
Memory card locked!??
The card locked usually means 'protected' Check out the manual for image protection - on/off. Or put card back into computer and delete[NOT FORMAT] from there. A more comprehensive manual is usually found the the CD that came with the camera
Jul 05, 2007 | Pentax Optio E10 Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
125 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
