Main board is the problem, www.shopjimmy.com will have the part you need.
Testimonial: "Thats what I thought you meant thanks"
sorry main board meaning the power board of the logic board?
or the*
No. The board with all the inputs and tuner. This board controls the power supply board.
Did this fix your problem I have the same issue
Did anyone figure out which board it is that's causing this? I just replaced the power supply board and that didn't fix the problem. Any help would be appreciated...
Check your other voltages coming out of the power board and see if they drop off when the set shuts down, all the 5 volts does is supply standby voltage and that should be there all the time even if the set is off. A suspect on this set is LED lamps in the panel but it could be other things as well
Front Panel Header pin assignments as follows:
Pins 2 + 4 = Power Led
Pins 6 + 8 = Power Switch
Pins 12 + 14 = LAN Activity Led
Pins 1 + 3 = HDD Led
Pins 5 + 7 = Reset Switch
Pin 9 = +5v
Pins 11 + 13 = ODD Led
Pin formation is as below with no pin in position 10.
2 4 6 8 10 12 14
1 3 5 7 9 11 13
You will probably need to extend the Front Panel connector cable to reach the header pins on a replacement motherboard - I did this with 2 x N76HL 10 pin extension cables (male to female) from Maplin.
I replaced everything! All cables and All boards! Same thing! Do not buy any parts. Does the same splash screen and goes back off. Been to a lot of sites where nobody was able to fix it. I think it was a Chrome cast update that bricked the TV. Lot of user from 11/19 to 4/15/20 have the same issues. With the cost of power board or main board lots of people have just bought a new TV. I paid $100 for ALL the components from a broken screen 55L621U. Tested each component as I switched them out (even pwr/imput button, wifi, 3 boards, and all wires) to no avail. Power on splash screen the black screen and power off. No support on this one. Best Buy 389 for a new one.
