Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My flash drive keep asking me to format it - SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
    President:
  • 2,185 Answers
Check on your usb port, it is the one causing the problem.
To test, try plugging the flash drive into another usb port. If it did not ask you to reformat, then it was your USB port.
Kindly rate this solution.
Posted on Aug 01, 2009
I could n't access my files in my pendrive JF V30
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Sep 09, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My SanDisk Cruzer USB flash drive had problams with the U3 systam, So i uninstalled it by using the "renuve u3 luntch pad.exe." then I selected the "format adn keep my data" option, but the systam find a...
You have ruined the file integrity of the flash drive, There is a very slim chance that you will recover any data off of the drive. Most flash drives only have a read/write of about 8,000 to 9,000 times so depending on how much you actually used the drive, it is possible it finally went bad. To format the drive try going to my computer and right clicking on your cruzer drive letter and click format. "ALL DATA WILL BE ERASED WITH THIS OPTION"
Jun 21, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My mosearbaer pen drive cant be formatted and we also cant delete any files in the pendrive???
virus in your pendrive.
so format your pendrive dos command
start than run than type cmd than enter
ok and command type is
format (your pendrive colon) enter
i sure your pendrive format.
Feb 26, 2010 | Electronics - Others
Pen drive is not openning asking formatt & not
Try to format it using the method describe below:
May be it will help
Go Start>Setting>Control Panel>
Or Start>Control Panel>
Then open> Administrative Tools>Computer Management>
Then select In the left Column Click disk management
Then locate your pen drive and try to format with fat file system
Also you can try to remove the partition and create new one
ok...
Regards
Uttam
Jan 16, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pen drive not opening and say format and not formatting
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Nov 04, 2009 | Fuji (MAP3367NP) 36.7 GB Hard Drive
Can't access my Verbatim 2.0 Flash Drive
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Mar 19, 2009 | Verbatim USB 2.0 HD DRIVE 12GB STORENGO 12...
Kingston U3 Flash Drive malfunctioning
. have you tried the Flash on another PC?? if it's the same error you get, i am afraid you Flash has a Malfunction. The only option is to format the device & use a Data recovery software to recover the data on the disk. but this is not guaranteed as there is a chance of you loosing some data as well the recovery cost
Mar 19, 2009 | Computers & Internet
Hi I have a Flash Drive 4GB it says it is write protected when
This is a bear of a problem with Transcend owners. You need to use their new Jet Flash format utility. So before doing so, copy everything off your drive to a folder in My Documents. This tool will then format your drive so you can start adding new, more organized data of your choice.
Then, try to remember to keep your data on the pen drive below the 4GB limit. This all has to do with binary math and base 10 math. The drive really doesn't hold 4GB of data, its way lower than that around 3.6GB. So, keep this in mind and keep this format tool around for future use.
I found this download link here, which is dynamic and not static but should work by clicking here.
Should that not work go to this referrer page here. You will have to start by select your product type and then go down through each selection list until you find your model and then the downloads for it will be listed. Click on the Jet Flash utility download eventually.
Personally, I think they could have done this much better and made this way simpler for consumers to find the formatting tool.
Let me know if you run into trouble and if you don't hear from me in 24 hours click on my user name and send me an Ask Me message, I'll get that message and I'll be glad to help you out.
Regards,
Worldvet
Jan 19, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Windows asking me to format my flash drive
Just format your flash drive! Before you start formatting your flash drive, transfer all data from your flash drive 'cause when you format your flash drive, it will erase all the data. After you have formatted the flash drive, then you can transfer back the data to your flash drive.
Dec 20, 2008 | Computers & Internet
It keeps asking me to format the disk
If it cannot complete a format, you want to return it as a defective item, where you purchased it, for replacement.
Dec 05, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
1,152 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
