Question about Vocopro UHF-3200 Professional Microphone
No sound from MIC but the RF light is growing
    Problem Solver:
  • 7 Answers
Is it a power mic change battery also check white wire connection
Posted on Aug 02, 2009
Pyle troubleshooting
You've obviously checked battery strength, battery connection and volume settings for the dead mic...does the green transmit (RF) LED light when you turn the mic on? Does the red audio (AF) LED light when you talk into the mic? Best solution....buy a better quality wireless system ($85 wireless?!? ...no thanks).
May 20, 2014 | Pyle PDWM2100 Microphone
No mic audio
Hi
cordless mics consist of the following parts:
mic capsule- audio and copression amp- Xtall and RF section.
In your case RF is ok. Test mic capsule ( using an audio amp or simply connect it momentarily to a 1.5 vollt battery and listen for a "khesh" noise from your capsule. If your mic capsule is ok your amp and compressor section is either damaged due to a reverse battery connection or you have " cold solder joints" on or around the audio amp. E mail me if you want further information at: moska.1982@yahoo.com
Sep 08, 2012 | Audio Technica Audio Players & Recorders
When ever i dead key the mic on med rf power i get a humming or bumble bee sound through my talkback same thing on high rf power i changed the coax it helped it for low rf power and tried new mic but had...
Thats because your Rf is powerful on high settings..try taping a AM radio "ferrite bar" to your coax in the back of radio for "RF filtering". Keep your power supply 15 inches away from radio. I recommend unhooking talkback on radios (it always causes feedback). But make sure speaker is good distance from the radio. I'd say 10 feet or so, behind radio. Change external speakers or add one with a long cord.
Apr 23, 2011 | Ranger Virage VX-38 Base CB Radio
Dont have any rx sound
check your antenna, coax, and all connections.
Make sure if you have an RF gain it is all the way up. make sure squelch is not to high.
If that doesn't help, your mic may be bad. If you have a bad mic, you will get no audio. If no mic, no audio. try a new mic if the first steps do not help.
Mar 02, 2010 | Radio Communications
I turn it on. The lights are on but there is no
Mic plugged in? RF gain all the way to the right? Antenna?
Feb 05, 2010 | Superstar SS-121 120-Channels Base CB...
I have a cobra 29ltd crome had echo board installed works good till i trun my la 900 on get feed back or squilling how do i fix
LA 900? I am guess that is a linear amplifier. If so are you running a power mic? You are probably getting RF feedback. You need to turn the gains on the radio and mic down.
Some things you can try. Hold the mic cord in your other hand in the center of the cord while you key it. some times this will shield it form stray RF.
You can also get a bunch of RF chokes from radio shack. They are little black things you snap onto wires that shield form RF. Put 2 near the plug, and 2 near the mic. That will help shield it from RF.
you will most likely still have to play with the gains on the radio and mic to find a sweet spot where it doesn't squeel.
Oct 06, 2009 | Radio Communications
When i key up the mike the tx/rx light and the ant
your swr setting are off wack fix your swr
Oct 02, 2009 | Cobra 29 LTD CB Radio
The ant light and the other light light up red when i key the kic
the tx/rx liight is green when your radio is recieving signals and turns red when you are sending signals. the ANT light is red when your SWR is too high (over 3)
1. turn the knob labeled swr cal all the way counter clockwise
2. set the rf swr cal switch to the CAL position
3 key up the mic and hold it while you rotate the swr cal knob until the needle reaches the swr cal postition
4. set the swr cal rf switch to the swr position
5. key up the mic while on chanel one (record the the number)
6. switch to chanel 40 key up the mic (record the number)
if the number on chanel one is lower than the number on chanel 40 then your antenna is too long.
Sep 14, 2009 | Cobra 29 LTD CB Radio
What setting do i use to run my cordles mic in to audio 1
Without more clarification I am assuming that you have the onboard mic plugged in normally & I don't know where the RF mic is connected.
First thing is that we know that you get sound from the shotgun mic in ch. 1. If you do not plan on using the onboard shotgun, then the fix is easy! Since it has been confirmed that ch. 1 works, just disconnect your shotgun & plug in the RF receiver to that, check your levels, and shoot away.
If you are still wanting to use that shotgun along with the RF, then I suggest that you re-read pages 51 - 54 of the instruction manual. You can find where to jack in, how to set, and change audio levels on these pages. Good Luck!
Feb 10, 2009 | Canon XL1S Mini DV Digital Camcorder
Magic-Sing EG-18000 works, no sound
look and see if the RF light is coming on, if it is not then the transmitter (mic) is not on the same frequency as the receiver.
Nov 22, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
174 people viewed this question
Top Vocopro Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Vocopro Audio Player and Recorder Expert? Answer questions, earn points and help others
