Question about Boating
I need a wiring diagram fo rmy Bass Tracker Pro-17 boat
  • fltrvrshhr Aug 08, 2009
    The ignition system.
  • Danny Rodriguez May 11, 2010
    Waht are you wiring?
4 Suggested Answers
captainjeffq
  • 52 Answers
SOURCE: need Wiring Schematic/Diagram for 89 Astro GT16 boat
In all honesty, its probably impossible to get the original wiring diagram. Also, I would be willing to bet that there has been alot of re-wiring and changes made to the wiring and electrical system of the boat. If you describe exactly what your trying to do, install fix or re-wire I may be able to better assist
Posted on Apr 14, 2009
  • 677 Answers
SOURCE: i have a 2005 90hp yamaha on a 17' xpress bass
Check the running height of the motor.The prop shaft should be about one inch below the straight line of the bottom of the running bottom of the boat.With a cleaver prop it may be lower.A chopper prop is the best and you can run every bit of that.2 inches if pitch is = to about 500 revs.Try a few props 1st before you pay the dollars for a new one.The bouncing is the wrong transom height and prop.You don,t need a cav plate if the boat is set up right.(a cav plate extension like a manta).Bad dealers may want to sell you these.A well set up boat doesn't.I've set up and run a lot of ski racing boats and all have never needed any "bolt on parts".Its mainly a motor height and prop selection thing.Hope this helps
Posted on May 05, 2010
jaballou
  • 63 Answers
SOURCE: mice ate wiring
Try to trace all wires and see if the metal part is still intact. Do not turn it on or allow electricity to pass yet! If wire metal intact, get some good quality black electrical tape and carefully tape all the exposed metal. When done, test system.
To prevent problem, use moth balls, fabric softener sheets, or pine sol soaked on cloths to deter mice & rats. If possible, use old- fashion mouse or rat traps with peanut butter to kill intruders to your boat. If you agressively eliminate them, the problem will be solved, but you may have to periodically repeat the trap use.
Posted on Dec 16, 2008
Where can I get a wiring diagram of a fishing boat?
If this is a Tracker boat then contact Tracker with the hull identification number and they will provide the diagram. I have no experience with other manufactures.
Mar 12, 2016 | Boating
1995 Cajun bass boat. Where can I get a wiring diagram?
cajun manual and parts manufactures
www.bbcboards.net > BBC Boards > Bass Boat Forums > Cajun Boats
Jul 18, 2011 - 13 posts - ‎11 authors
... for cajun boats and also a complete manual in pdf format and wiring schematics. ...bassmannbama is offline ... a wiring diagram too because switches arent working andmy wiring ... My email is : steve1995z@hotmail.com.
Cajun Boats Owner's Manual 1992+ available on pdf
Apr 19, 2012 - 4 posts - ‎4 authors
I scanned in my owner's manual and have it available if anyone is ... Mine is a '95 1950 Fish n Ski, but I believe it would cover bass boats as well. ... Looks like I'll need to learn about electrical and general boat repair.
Nov 19, 2015 | Boating
Instrument panel switches do not work on 1987 bass tracker
I would suspect corrosion try some contact cleaner from radio shack..
Jul 14, 2014 | Bass Pro Boating
Troubleshooting bass tracker boat
kill switch possibly problem.
Jun 26, 2013 | Boating
I have a 1988 bass tracker ingnition switch won't
Hello cainld04,
Sounds Like The Start Solenoid Is Not Working.
When You Turn The Key To Start You Should Hear A Click ,If Not Solenoid Is Probably Bad,If Yes Then Starter Needs Service.
Hope This Helps.
Gordon
May 10, 2012 | Bass Pro Boating
Bass tracker fuse descriptions
I was trained at a tracker dealership and that is one of their faults. The best way to find the fuse for the bilge pump is to look on the back of the bilge switch and trace a wire to the fuse panel. Most of the time they are color coordinated so you can match fairly easy without trying to manually probe for the wire.
Jun 10, 2009 | Boating
Boating Logo
1,535 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
