Question about Eureka 2961AVZ Bagless Upright Vacuum
Low suction Replacing filters....need help replacing the belt - anyone know how? But before doing these things, have had a problem with suction....I'll let you know if the problem clears up.
  • jabdesigns Aug 02, 2009
    I was able to change the belt as you describe, but you were much better at stepping through the details. Yes, there were two screws on the top of the beater bar housing, one silver screw on each corner. One additional note - the beater bar sockets are actually hexagon shaped, so the beater bar ends will need to be aligned correctly to fit back in the sockets. Note that your NEW belt will probably have a lot more tension on it than the old one (which is why you're replacing it!), so it may take some elbow grease to pull the bar up into the sockets correctly. Oh, and bty, with the new filters and belt, the vacuum works like new! Great suction again. Thanks again for your help.
    President:
  • 1,273 Answers
Hi, You can take care of both things at once. Here's how:
Unplug and flip your vacuum over, beater bar side up. Remove the cover base plate that surrounds your beater bar. It's held on with either clips or screws, and usually "hinges" toward the front of the vacuum to release when the clips/screws are undone. Remove the base plate. The beater bar sits in sockets where it fits into the vacuum. Pay particular attention to how it comes out as you remove the beater bar, so it will be much easier to put it back together. If your belt is good, it will want to come off with the beater bar, but will remain attached to the motor. If necessary, slip the belt off of the beater bar. Behind the beater bar, you'll see a cavity. This is where the vacuum pulls the dirt from the beater bar. Look up into the cavity; stuff almost always hangs up in there. Remove any debris that you can find. While you have your beater bar out, look at the ends, where it fits into the sockets. Hair and other material catches on the beater bar and winds around it. If it is in and around the sockets, it causes the vacuum to have to work harder to clean. Remove any debris that you find on either end. Get your new belt and place it on the motor shaft. Slip the beater bar into the belt, and install the beater bar and sockets back into the vacuum frame. It takes patience so don't worry if it takes a few tries to get it right. Once in, test your work by revolving the beater bar a bit with your hand. You should be able to feel the tension of the belt as it turns the bar and the motor shaft. Take one more look at the sockets, just to be sure that they are in the proper place, and that the beater bar is level in the frame. Reinstall the base plate. This should have you finished at this end.
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Posted on Aug 01, 2009
Dc4 has low suction
HI, it's Jim from Crucial Vacuum!
Low suction from your Dyson DC07 can be directly related to basic vacuum upkeep and maintenance. Here's some simple things you can do for your vacuum to help ensure optimal performance and to keep your vacuum running for a long time with great suction.
After every use, make sure to empty your Dyson's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged.
Wash and clean your unit's filter screen weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours. Be sure to allow it to FULLY dry.
Foam and cloth filters should also be washed and dried weekly, by following the same steps from cleaning the filter screen. Do not use any soap, dishwasher, dryer or washing machine to do so. Allow your filters to air dry for 24 hours before re-installing them in your Dyson.
Last, make sure to clear your brush roll of any hair strands or debris monthly and to replace at least every year. When examining your brush roll take note of the condition of the bristles. Are they loose? If so this would be a good time to change your brush roll.
While checking the brush roll you might as well examine your Dyson's belt. With use the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. So if your belt feels loose as well replace that.
All of the previous general maintenance tips will help improve your vacuums suction and overall performance.
You can purchase your replacement parts for your Dyson DC07 direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=DC07&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Dec 29, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuum not clogged but has low suction
Check all the pipes, there could be something stuck in them which hasn't come out.
Also check the base of the vacuum if there is something stuck in the base.
Lastly check if there are any leaks in the pipes.
Also check the suction without using the handle, by pulling the pipe in your hand and see if it has more suction.
Apr 28, 2014 | Hoover U6630-900 WindTunnel Bagless...
Low suction
REplace the filters and belt. If it's been a few years since it's been serviced take it to your dealer. The 8955 can work properly for many years but there are some things that will need cleaned and service to work properly.
Oct 27, 2013 | Riccar 8955 Upright Vacuum
Loss of suction
If it is not picking up from floor replace the belt. They need replaced at least twice per year because they lose elasticity and will slip when vacuuming floor. If it is loss of suction start by replacing filters. All filters should be replaced at least once per year on most vacuums
Oct 25, 2013 | Vacuums
Bag was not on good, resulted in dust,dirt, dog hair everywhere...have cleaned pretty thoroughly but vacuum does not have any suction. After taking apart did find that the larger wide belt is broke but I...
Greetings from GoVacuum,
There are two things that you should check on this vacuum after running it without a bag inside. The first thing you should check is the filter that is underneath of the vacuum bag. This filter is underneath of a bracket, and the bracket can be removed by pulling straight up on the bracket. The bracket and filter are directly below the vacuum bag inside the vacuum bag housing. If the machine was run without a bag (or the bag fell off) then this filter is most likely going to be extremely clogged. You can simly remove the filter, and run it under hot water until clean. Make sure the filter is 100% completely dry before putting it back in the vacuum and using it. Running the vacuum with a wet filter will destroy your motor.
Now in terms of the belts. Where as the belts don't directly control the suction of the vacuum cleaner, they certainly facilitate the pick up of dirt and debris on the floor. Many people assume that since the vacuum is not picking up from the floor, then the vacuum doesn't have suction. You can test this by pulling out the attachment hose and feeling for suction, is there suction at the end of the hose? If yes, then the reason the vacuum is not picking up on the floor is because of the belts. If you don't have suction at the end of the hose, then you have a clog, some where or a dirty filter.
The belts actually are what spin the brush, and the brush basically sweeps the carpet, and throws the dirt and debris into the suction port, and when the dirt and debris are near the suction port, the suction then takes over and takes it to the bag.
There are two belts on this model, it's best to replace both of these belts at the same time. If you replace just one, then the other belt will wear out quicker. It's always best to replace these two belts in conjunction.
The two belts that are used on this vacuum are:
Hoover Windtunnel V-Belt Part 38528034
Hoover Windtunnel Flat Belt, Hoover Part 38528035
Once you have the belts, and you're ready to replace them, here's a great video that we shot here at Govacuum.com that shows you exactly how to replace these belts, as well as some basic maintenance on your roller brush;
I really hope that my repair solution was helpful to you in fixing your vacuum cleaner. If you have any further questions about this repair, or any repair, feel free to contact me at chris.jones@govacuum.com, or request a clarification here on Fixya.
If you did find this repair solution helpful, please kindly rate this repair helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of this solution.
Thank you very much,
Chris Jones
GoVacuum.com
Mar 19, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Our DC17 is loosing suction. How many filters muist be cleaned?
This video is for replacing the clutch & belts, but it also shows how to take out the hose underneath & inspect it for holes or damage to see if that's causing suction issue http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
Dec 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bissell cleanview vacuum poor suction
The next thing that you need to do is replace the belt. Even if it's not cracked or worn, many times it's too loose, and it won't turn to rotor efficiently.
Believe it or not, just replacing the belt may be all that you need to do!
Jul 07, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Whiny motor, less suction
Its not unheard of that the lifetime filtration filter may need replacing and dust can work itself into the main motor chamber even though Dyson claim their models have sealed motors. Whiny motors however can happen for a number of reasons such as:
  • Over-use
  • Motor bearings
  • Strain on the motor from another source i.e. the drive belt may need replacing or the caps on the brush roller at each end need to be checked.
Have a look at the drive belt / sole plate to see if there is any dirt clogging the system. Also check the inspection pipes on the Dyson and check that nothing is obstructing the air waves. Sometimes even a new filter (bottom of the bin) cures the problem and this can easily be checked by taking out the filter for a couple of seconds and using the Dyson to check if suction is indeed stronger.
Jul 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
How to for Belt replacement and solution to suction loss
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
Jan 05, 2008 | Vacuums
Eureka 2961AVZ Bagless Upright Vacuum Logo
476 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
