Question about Kenmore Sewing Machines
I have a semi-computerized machine from 1981, model 17921. The tension has been wonky for several years, and now I am having difficulty getting the needle out of zig-zag position and back to straight stitch...it doesn't want to move back to center. My tension shows a thread sitting on the bottom almost completely loose and the top thread tangling, occasionally getting tangled and mangled in the bobbin. I was told once that the tension wheels are wearing, and that corrosion was building up inside, which I had cleaned up. However, the tension wheels have not been replaced. It has been oiled and checked out, but the shops here never seem to fix it.
  • julieburnsid Aug 03, 2009
    I took it to a repair shop, the same one who told me a few years ago the tension wheels were wearing, and he condenscendingly told me there was nothing wrong with the wheels. My needles are new, I have rethreaded several times, ensuring that the thread was between the wheels. I cannot get him to understand that the design selector is not working and that the needle position is wrong (it is normally set slightly to left of center when in straight stitch). Unfortunately, he is the only repairman who has any competence in the area, and I drive 45 minutes to get to him. On this machine, you push a large selection knob and then dial to the stitch design you want. The width seletor is just above the knob. Normally, the needle should move appropriately to position. However, it sometimes sticks in the far right position (which is where it stays...it does not seem to stick in the far left position). This position is bad for two reasons, one of which is that it misses the hole in the zig zag foot and the hole in the plate, snapping the needle and putting a needle dent in the top of the plate. Is there still a Sears repair shop in the country? I would be willing to go through sewing withdrawl for a month if I could get it repaired somewhere in the country.
  • 10,865 Answers
Your tension wheels are worn out. Replace them and you will solve your tensioning issues. Good luck.
Posted on Aug 04, 2009
    President:
  • 2,185 Answers
Yes you are right, the tension wheels are wearing, alright.
I believe your machine is out of alignment in some way and needs a trip to the repair shop.
Sewing machines need tune-ups just like our cars so it will probably benefit from a thorough cleaning and professional adjustment.
Posted on Aug 01, 2009
  • virtualhost
    virtualhost Aug 01, 2009
    Is it an old needle? Also try putting in a new one. Sometimes they just get bent. Try re-threading.
When I move my needle to 4.0. Or 4.5, the needle now moves to far over to the right.
The needlebar position is off. You may want to take it for service.
Do you like this machine? You've used it for several years, know how to use it, etc. What does a general service cost? Perhaps $100-150. So where would you find a replacement machine for that amount? It is generally recommended that machines be serviced once a year, so you have saved enough over the years to afford a service call.
IMHO, I'd rather fix an older machine that I love than buy a new machine that doesn't work as well as the old one...
Oct 05, 2016 | Janome Memory Craft 9000 Computerized...
Bobbin case won't stay in correct position
you need to have the machine checked to see if the hook & hook race
may need to be replaced & the machine may need also to be timed
a repair shop can tell you for sure
Sep 02, 2012 | Brother CS6000i Computerized Sewing...
I need several parts for my brother CS8150
sewingpartsonline.com
a1sewingmachines.com
sew4less.com
sewvacdoctor.com
ebay
Apr 19, 2012 | Brother CS-8150 Computerized Sewing...
Acquired a used Kenmore 158.1792 model sewing machine and when I sew, the thread on the underside is all knotted up and in excessive amounts! How do I keep that from happening? Thank you!
Sounds like a tension problem. Do you have a manual ?? If not, they're available online for $5 to $10 as a PDF problem. You'll want to check the top tension, and the lower bobbin assembly.
[ I've got one of these machines, and used it for many years, although sadly it now has a burnt-out motor, and the motors are difficult/impossible to find ]
Feb 22, 2011 | Kenmore 19110 Computerized Sewing Machine
I have a singer quantum 9910 that I have been using for years. As I was quilting a project the upper thread tension started to go wonky. I have taken the machine apart to clean it, changed the thread and...
I would say that it probably is time for a tune up, they are kind of like cars and need to tuned up every so often. Luckily, not as expensive as cars. Good luck
Sep 06, 2010 | Singer Quantum 9910 Computerized Sewing...
Hi i want to buy a sewing machine wich one is best. kenmore or brothers sewing machine
I would prefer Kenmore, enmore makes perhaps the largest selection of mechanical machines. The very cheapest Kenmore sewing machines, like the Kenmore Mini (*est. $100) and Kenmore 15208 (*est. $120), stick with a four-step buttonhole, and have just six and eight stitches, respectively. The Kenmore 15212 (*est. $150) and Kenmore 15218 (*est. $170) both have a one-step buttonhole. The cheaper Kenmore 15212 has 12 stitches. The slightly more expensive model has 18 stitches, including a smocking stitch, overcast and elastic stretch stitch in addition to the basics. Both Kenmore sewing machines are good, basic models, say reviews. Both have just a 90-day warranty, however. Bear in mind that Kenmore sewing machines are made by different Asian companies each year, resulting in varying degrees of quality; this also explains the low prices. Some users report difficulty with tension and light fabrics.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 03, 2010 | Kenmore 19365 Computerized Sewing Machine
Hello, i am having problems! I was sewing fine and then all of a sudden i started having loopies and bunching coming from my bobbin. I have tried a new bobbin, there isnt any thread in the area, i have...
You have done everything you can do.
If you thread your machine with the presser foot up (this allows the thread to seat into the tension control), then it may be the machine needs to go into the shop for service.
When the tension cannot control the thread, the bobbin thread cannot knit with the top thread - it looks like a bobbin issue but is due to lack of control of the top thread.
Try one more time, threading with the foot up and if the problem continues.........take a sample of the stitching as this may well be a timing issue.
Be sure to go to a Brother dealer so you do not void any warranty coverage (timing would only be covered during the first year).
Mar 28, 2010 | Brother SE-270D Computerized Sewing...
Difficulty adjusting tension to avoid bobbin looping
it sounds like your bobbin tension is too tight. to adjust bobbin tension, remove bobbin case (remove needle plate first) and adjust bobbin tension screw on side of case until bobbin thread has a slight resistance as you pull it through the bobbin case.
this will be trial and error until you get best result. you should always try and match top and bottom threads. if the top thread is quite thick you may have continue to increase needle thread tension until balanced.
scott
Jul 26, 2009 | Brother CS6000i Computerized Sewing...
Top tension adjustment
Believe it or not, most computerized machines have an automatic tension. This works well providing, the thread is thru the tension wheel setup.
But for further reference,
loops on the bottom-- problem on the top.
loops on the top--problem on the bottom.
Mimi
Apr 23, 2009 | Singer CE-100 Futura Computerized Sewing...
Tension Problems with Janome DC3050
If your machine is binding. It sounds like you have a threading problem. Check your manual and rethread the machine. The A is for Automatic tension I would not change that. I would also notify your dealer and see if you have thread under the bobbin case. All sewing machines should be serviced each year.
Dec 13, 2007 | Sewing Machines
Sewing Machines Logo
43 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
