Question about GE Dishwashers
I have a GE potscrubber portable dishwasher and when i connect the hose to the facet and plug in to the outlet and turn the dial to start the dishwasher up all i hear is a low humming sound. I tried truning the knob around a few times and still the same low himming sound.
I have this same problem with the same dishwasher. Did you ever find what was wrong with it?
Posted on Jan 17, 2010
How do I uninstall my dishwasher?
Turn off ALL power and water. Move machine until you can see the hoses and power point. Unplug power and switch off, disconnect hoses and turn off any taps/faucets. Fully remove machine. Turn power and water for residence back on.
Aug 11, 2014 | GE Dishwashers
Attach hose to sink
what is your question? if it is how to attach there is an adapter that screws on to facet and then you connect the hose piece to that.
May 07, 2014 | Danby DDW1899WP 8 Place Setting Portable...
I have a GE 1200 Potscrubber portable dishwasher it was running good until it started to drain then water started coming out the bottom is there a way to fix this? Please help me.
You can take the unit and lay it down. There will be some water leakage. You can then see the hoses and connections. Sounds like the drain hose is either cracked or loose.
Feb 08, 2014 | Dishwashers
How do you remove the sprayer arm from a GE potscrubber 600
Thought I had a problem with the spray arm or pump because water was not flowing enough to spray the upper rack. But it turned out it was a simple part missing: the "check valve" that is in the lower neck of the spray arm assembly. It's a $10 part. Part #WD1X5488 for GE Potscrubber 600.
May 20, 2013 | Dishwashers
My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Dec 07, 2009 | Dishwashers
I have a GE Potscrubber dishwasher that only hums, won't run
I have a portable that had the same problem. I called a repairman and he turned a fan blade on the motor. Mine is located on the right side about 12" in. It gets hung up when it is run often enough. If your problem is the same is mine all you have to do is turn the blade and it works like a charm. Hope this helps.
Feb 18, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
I have a GE roll around dishwasher, Model GSC3200Z03BL. It worked one night, did not work the next. After hooking intake/discharge hose to faucet and turning to start, no water is pumped in. Only a...
First off.. the pump does not let water in.. it takes water from your sink faucette via the hose and allows it to enter the DW via an inlet electrically operated valve. If that valve is not commanded by the control system to open, then no water will enter the DW and a wash cycle will not start. Please find the informaton shown below that decribes some reasons why your DW may not be filling with water. You should go thru this series of checks to make sure you've set up the DW correctly aqnd it is not in mid cycle.If by chance you are setting it up correctly and are not in mid cycle then you may have a hardware problem with the system. I would be happy to assist you if it comes to that but I am hoping that the information below will get you started,...
Copied directly from the GE website for your refererence..
Dishwasher - No Water Fill
Often the cause of a dishwasher not filling at the start of its cycle is not electrical or mechanical. Often times you may be starting your dishwasher model incorrectly which results in the machine skipping its first water fill period.
There are presently three different types of starting procedures being used:
  1. Pushbutton type. This system is found on all POTSCRUBBER models.
  2. "Turn-to-start" timer type. After latching the dishwasher door, you turn the timer dial until you hear a click. By advancing the timer dial beyond that point, its possible that the first water fill would be skipped. The first fill is necessary for automatic pre-rinsing of the dishes.
    View a short video about turn-to-start timers:
    Play Video
  3. The most common type is a "push-to-start" timer dial. All that is required to initiate the cycle is to push in on the timer dial. It is NOT necessary to turn the dial.
If you are unsure as to the starting procedure used by your model please consult the Owner's Manual. Download a free copy of the Owner's Manual and/or Installation Instructions.
Here is a link to the website too.. http://www.geappliances.com/search/fast/infobase/10001005.htm
Hope this gets you going..
Sep 02, 2008 | GE Dishwashers
GE potscrubber 700
upc leaks when dishwasher is emptying
May 12, 2008 | GE Dishwashers
Dishwasher not washing
sounds like the wash pump (wich recirculates the water during wash) has something stuck in the impelor or the wash pump motor is faulty. someone qualified would have to check this for you
Feb 18, 2008 | Dishwashers
Dishwasher
GE 720 Potscrubber I started with the water puddling in bottom now it progressed to leaking on the floor. I had a repair guy come to my home yesterday and he says a broken seal and my total cost to replace seal and labor is $165 plus tax.
What is the life expectancy? He did not sound too promising about the future of my dishwasher and said he is certain there will be another repair need shortly something related to the water saturating an area underneath the dishwasher?
He reccomended I call Sears and replace with a Whirlpool product. He claimed he put his kids thru college repairing GE products. My husband wants to repair and I dont because of fear of spending more money!
Jun 18, 2007 | GE 24 in. GSD2600GBB Built-in Dishwasher
Dishwashers Logo
648 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
