Question about Maytag M3X05F2B Air Conditioner
All of a sudden the air conditioner no longer cools, with hif=gh or low thermostat settings. The fan for "Fan" and "Cool" settings works normally
    Problem Solver:
  • 8 Answers
Sounds like the outdoor unit is not working check breaker and then the capacitor
Posted on Aug 12, 2009
Tip
Air Conditioners Cooling Tips
  • Whole-house fans help cool your home by pulling cool air through the house and exhausting warm air through the attic.
  • Set your thermostat as high as comfortably possible in the summer. The smaller the difference between the indoor and outdoor temperatures, the lower your overall cooling bill will be.
  • Avoid setting your thermostat at a colder setting than normal when you turn on your air conditioner. It will not cool your home any faster and could result in excessive cooling and, therefore, unnecessary expense.
  • Consider using an interior fan in conjunction with your window air conditioner to spread the cooled air more effectively through your home without greatly increasing your power use.
  • Avoid placing lamps or TV sets near your air-conditioning thermostat. The thermostat senses heat from these appliances, which can cause the air conditioner to run longer than necessary.
  • Plant trees or shrubs to shade air conditioning units but not to block the airflow. Place your room air conditioner on the north side of the house. A unit operating in the shade uses as much as 10% less electricity than the same one operating in the sun.
  • on Sep 21, 2010 | Heating & Cooling
    I have a rooftop ac unit on my popup that was replaced two years ago. The unit works fine but I would like the fan to shut off when the compressor isn't running. Is there a switch for putting the fan...
    Please describe your controls. Does it not have low fan, high fan, low cool, high cool on the dial at ceiling? If yes, low cool or high cool setting should shut it down when temperature is reached via thermostat dial.
    Aug 29, 2011 | Dometic Rooftop RV Air Conditioner
    Bought 4 small Gold Star units in 2009. One quit cooling altogether, one blows slightly cool while the longer another stays on the less it cools. One did not cool well when it was new. All filters are in...
    http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28700000&pkw_=basket&model_id=5520000&NewWindow=1
    Download this illustration and then using a good multimeter start basic troubleshooting.
    All residential window air conditioners have a cooling system made up of four primary components, a compressor, an evaporator fan, a control or switch, capacitor.When the thermostat is calling for a colder room temperature the compressor is energized. It is normally very quiet. The evaporator is always located on the front of the air conditioner. It also has silver fins. Be sure it is clean. Use a foaming type cleaner and rinse with plain water. Because the evaporator is absorbing heat, it is very cold to the touch. The temperature drop causes any humidity in the air to collect on the evaporator - sometimes called sweat. There is a fan inside the air conditioner that circulates the air for the evaporator and condenser coils. The circulating fan and compressor are running simultaneously. The fan motor has two fan blades attached to it on either end. The fan blade on the inside part of the unit continually draws room air over the evaporator coils, which are cold. The fan blade on the outside part of the unit continually draws fresh outside air over the condenser coils, which are warm. Because the evaporator coils are cold, they cause moisture in the room to collect on them, much like a cup of ice water on a warm, humid day. When the amount of moisture increases, it begins to drip down off of the coils into the bottom pan of the air conditioner.
    If the compressor fails to start or the fan you may need to replace the capacitor.
    You may need a hard start kit.
    Thermostat control The thermostat on a window air conditioner works by sensing the air temperature entering the air conditioner. As the air entering the unit reaches the set temperature it will cause the compressor to turn off. The blower may continue to run depending on the selection chosen on the control panel. Digital thermostats work on a similar principle but display a more precise temperature.
    Test for continuity with the multimeter between the two terminals . Warm you should read continuity (contacts closed). If not change it.
    Selector switches The air conditioner selector switches allow the user to choose the fan speed. The compressor always runs at the same speed regardless of the settings. If low cool is chosen, for example, the fan runs at a slower speed but the compressor still offers the same cooling capacity. There are other switches to control louver operation and other features on some units.
    Jul 23, 2011 | LG Goldstar GWHD5000 wall/window Air...
    Ac unit will not cool.
    Yes, that is normal operation if you have the fan setting to "on"
    heatman101
    Jul 09, 2010 | Heating & Cooling
    Model #LG LWHD1500ER The fan to cool no longer runs on the low speed. It will just humm. On "energy saving mode" the unit does not always turn on to cool. On the "cool mode" when the fan is on high it...
    www.appliancefactoryparts.com/content/.../118816.pdf - United States
    Above is your service and repair manual, with this you will be able to troubleshoot and repair your Aircon.
    I suspect, your thermostat may have a faulty sensor?
    factoidz.com/troubleshooting-your-air-conditioning-thermostat/
    http://www.inspectapedia.com/heat/Thermostats.htm
    Below is a DIY AC, troubleshooting how to. http://www.repairclinic.com/Air-Conditioner-Troubleshooting
    Jun 26, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
    My RV AC unit was runs good on high cool last night but this morning it was only running on low fan(some what cooling it Seems)What should I check first. thermostat,fan ???
    low medium high speed of fan iscontroled by selector switch on the thermostat or recheck the thermostat if ok check control wirnig from thermostat to the fan relay on control borad and from relay to the motor.
    Sep 03, 2009 | Dometic Rooftop RV Air Conditioner
    Soleus KFGHP-09-ID Mini Split
    This is normal operation for these styles of minisplits. The thermostat is not in the remote but is located on the return air of the indoor coil, so the air needs to be flowing in order for the thermostat to measure the rooms temperature. Set your fan speed to auto and the fan will slow down when setpoint tempurature is met.
    Phil Hodges,
    Tech support Soleusair
    May 18, 2008 | Soleus KFS18GW 18,000 BTU Heat & Cool 230V...
    Fan speed on cool setting only works on low
    If it's in Energy Saving mode, that may be normal.
    Geno
    Feb 25, 2008 | Comfort-Aire EKTC12-150J Air Conditioner
    Fan speed trouble on cool setting
    1.check selector switch of airconditioner.
    2.capacitor of blower fan motor.
    3 wiring of airconditioner.
    4.replace selector switch.
    Maytag M3X05F2B Air Conditioner Logo
    105 people viewed this question
    Top Maytag Heating & Cooling Experts
    Bill Long
    Donni Steen
    Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
