Question about GE Freezers
Freezer door won't close - plastic piece that goes under door is raised up and blocking door from closing
    President:
  • 1,273 Answers
There are several type of attachments, so pick the one best suited to you....
1. (most likely) With the door open, pull on the plastic panel. If it is held on by clips, it will pull straight off. Look carefully at the clips on the panel. Usually, they bend out of position after being forced back on. Adjust the clips, and gently press back into place. If they are damaged, the clips can be reattached with a 2 part epoxy. I prefer JB weld epoxy.
2. Locate the screws that holds the plastic piece on, and loosen them. Adjust the piece. Tighten the screws.
Best regards, --W/D-- please feel free to rate this solution! thanx!
Posted on Aug 01, 2009
Frezzer keeps icein over
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There are several things to check:
1.) Door Gasket -Take a piece of paper. With the freezer door closed run the paper around the gasket. If you can do that, then you are not getting a good seal.
Repair: Clean the freezer door gasket with soap and water. While still wet, take a hair dryer and a spatula, going around the gasket, heat the gasket while pulling the gasket out to expand it.
Note: This only solves the problem if there is frost in the front area of your freezer.
2.) Freezer fan not working - In some cases, The freezer fan helps to prevent warm air from getting into the freezer.
3.) Food Storage - Make sure you do not overload the freezer, and that the food product is inside the bounds of the racks.
4.) Fresh Food Section Air Vent Wide Open - This is your probable cause: Heat goes to Cold like a magnet. When you open your fresh food section door and then close it you are forcing warm air up the vent that goes to the freezer. You probably have a broken air vent assembly.
Oct 08, 2014 | General Electric Top Freezer 21.0 Cubic...
Why is there Water on floor under my freezer
Hello C. Richard Robinson - Is the door being kept open too long or frequently? If so, try removing the items needed from freezer ahead of time so the door is not open as much. However, main possibly could be a poor door seal. Try checking this by placing a dollar between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If nothing is stopping the door then the gasket will need replacing and adjusting by a professional.
Jan 18, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
In my freezer, there is a blinking red light next to the icemaker on-off switch. What is it and why is it blinking?
It might be blinking because it hasn't been able to reach the required temperature or the temperature you have set. Probably leaving it close for one or two days, the light will go off, if not, you might consider changing the plastic isolation of the door, you know, the plastic thing that you see goes around the freezer door, best luck.
Jul 26, 2012 | Freezers
Door on new Kenmore freezer hard to open ... could this be a leveling problem? I wouldn't think it is an ice build-up problem since the freezer was only installed last Friday (9/24) and the ice maker is...
Check thoroughly for any obstructions, shipping tape, remaining pieces of plastic, in and around the doors, door frame, cabinet frame that the door contacts when closed, and around the upper and lower hinges. Do you hear any noises when opening or closing the door? Do you see the door rubbing on the inside liner as you open or close the door? Were the doors removed and replaced in moving? This last one, if it is the case, check the alignment at the upper hinges, loosen but dont remove the screws, and adjust the door away from center.
Sep 30, 2010 | Freezers
The open door alarm goes off when the door is closed
THE CONTACT INSIDE THE FRIDGE THAT THE DOOR MAKES CONTACT WITH MAY HAVE DIRT OR SOMETHING ON IT,IF IT DONT MAKE GOOD CONECTION WHEN CLOSED THE LIGHT WILL STAY ON AND THE ALARM STILL CARRY ON GOING OFF.ALSO CHECK THAT THE LEVER INSIDE PUSHIES IN AND OUT AND NOTHINGS BLOCKING IT.ROB
Sep 01, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Re: danby upright freezer 20.1 cubic ft., model #
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 13, 2009 | Freezers
Hotpoint Fridge freezer FFA74 Freezer Door Will not close
check that the part that the drawers slide into is in its proper position. try lifting up on door to shut. if this works u may have a broken cam riser. or u may be able to put a washer or two on hinge to raise door up for better clearance.
Jul 26, 2009 | Hotpoint Freezers
Freezers Logo
46 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
