Question about Fujitsu Heating & Cooling
Out door unit wont come on ,cant tell if its one flash or two never been started up yet.
    Novelist:
  • 166 Answers
There are a variety of factors that may cause your A/C to not turn on. With that said, here is a diagnostic article that provides the most probable causes of your A/C's failure to turn on, and from there you can read it and then, step by step, rule out each possible cause listed in the article:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Turn_On_At_All.htm
Read the article, and, actually, your best bet may be to take advantage--towards the end of the above-linked article--of the text-link for Free four (4) quotes from local AC contractors in your area (click the link that sasy"Find A/C Contracts. Get Up to 4 Quotes"), and "pick the brain"--seek the advice--of these local technicians who offer you a free quote to discern what could be the problem.
Posted on Aug 09, 2009
2003 VW GOLF REAR door wont open
The rear door lock actuator has failed in the door locking unit this is a common problem you can manually unlock the door to replace the latch if you didn't have the deadlocking on if you cant try pressing the locking button twice so when the car is locked the flashing red light is not blinking ie off on the drivers. Doing this usually causes the faulty lock to release the dead locking so you can pull the inside handle to unlock the door.
Oct 13, 2016 | 2003 Volkswagen Golf
Wont start
Try unplugging it and turning it on again. It is telling you something is not correct, it could be a simple thing as the door. Double check that the door is closed properly. Do it slowly, put some light pressure on the door and see if the lights go out. Good luck!
Feb 15, 2016 | Washing Machines
Can't get machine to start a cycle. When press the start/pause button, the door open light begins to flash. After a few seconds, it stops flashing and the start/pause button begins flashing. I have checked...
It is hard to tell if there is no model number. Normally, WP machine has error code appeared on the display. I guess your unit does not have display, so the combination flashing is a signal to tell you what wrong with the system. You can check the service manual normally taps inside the unit.
Oct 22, 2013 | Whirlpool Washing Machines
1995 jeep grand cherokee factory security wont stop flashing and cant start vehicle
Hi....
On your question.
Put the KEY in the Passanger door lock cylinder and turn.
If stop Flash will start ok.
If Not Do de same in the Rear Gate door.
It will deactivate the Factory Alarm.
I hope this help on your question.
Aug 13, 2010 | 1995 Jeep Grand Cherokee
Samsung WF7700N6W1 wont start because of 'door' error, door is closed
there is a switch in the door latch that tells the unit the door is closed so it can start to operate if there is a fault or a peace of the latch has broken off the unit will read door open check the latch for any broken off peaces if it looks good replace the inter lock unit on the machine
Jun 19, 2010 | Samsung WF328AA Front Load Washer
Pots &pans normal sani cycle lighs fashing..wont start lights wont go off..help!
If it is a slow blink on the start button it's something to do with your door switch. If it's a rapid continous flashing it's prob a short in your key pad. If it flashes 7 times, pauses and then repeats you have a fault with your heating element.
If it's a short with your key pad and the unit has water in it - stopped mid cycle you can cut the power to the unit at the breaker, open the door controls up and disconnect the 14 pin key pad connection. There should be a wiring diagram in the toekick cover (at the floor). This diagram will tell you how to do various tests, disconnect the key pad. If your not a handy type person call a repair man and tell him you think youhav a short in your key pad.
Mar 11, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
Can get out of thieft mode wont start
the "THEFT" light should always be flashing tells you its working, i have a 93 deville does the same thing, but if the alarm sounds alot make sure you dont open the doors with the handle or the unlock arm if the doors are locked only use the key or the button on the remote or buttons on the car door and if the alarm still goes off you might have an electrical problem
May 09, 2009 | 1996 Cadillac DeVille
Washing machine fault
Usually indicates door is not closed properly.
If it is shut securely, and still does not work, then you could have a faulty door lock.
Another possibility is the control unit could be faulty.
Nov 29, 2008 | Indesit W 123 Front Load Washer
My front loading washer wont start it flash E and DL i dont no what it means can you pls help me?
DL means door lock error. This happens when the door trys to lock 6 times but cant lock.
There a 2 things that create this problem. the door lock mechanism or the CCU ( central control unit )
Replace the door lock mech. first. if this does not fix the problem replace the ccu.
Nov 15, 2008 | Kenmore 46462 Front Load Washer
Flashing on/off start button
check your door switch, if unit doesnt think door is closed it wont operate
Feb 24, 2008 | Washing Machines
Heating & Cooling Logo
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
