Question about Troy Garden
Spark plug keeps fouling, turning black, hardly any power.
  • 305 Answers
Thats the sign of the fuel mixture being too rich, check , clean, or replace the air intake filter, that should solve the problem
Posted on Aug 01, 2009
Spark plugs keep fouling out, why
Monica, reasons for plugs to foul, bad fuel, wrong spark plugs, failing ignition components(wire,coil,points,etc),worn engine internal components(pistons,rings,valves), faulty/incorrect adjustment on carburetor,etc.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Technical information
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=spark+plug+fouling+chart
Mar 25, 2016 | Electrical Supplies
Blowing black smoke
far too much fuel not getting completely burned upon iginition.
That leads on to look at:
-fouled fuel injectors, (clean them - run injector cleaner)
-lack of air to the intake (filter and clear out tubing),
-spark plugs are fouled, (replace them, ensure wires seated correctly on plug)
-ignition power is low or partial, (ignition system module not sending enough electricity to plugs)
-ignition wires are bad, (check/replace)
-ECM is failing or getting bad sensor readings. (shop diagnosis)
-cat convertors have been removed and sensors are at fault
Its a long list -- do the easy stuff yourself, leave hard stuff to a shop diagnosis.
Mar 28, 2015 | Cars & Trucks
2002 harley electra glide front spark plug keeps turning black
Hi Anonymous, hopefully it's just gas fouled not oil fouled, noticed by white smoke out of exhaust. Anyways here is a short list of could be's: battery voltage, charging system, ignition components need at least 9 volts to function, spark plug, spark plug cable, ignition coil, ignition module. Good luck
Apr 09, 2014 | 2000 Harley Davidson XL 1200 C Sportster...
#2 spark plug black all others clean
The spark plug is fouled. Without seeing it, its hard to tell from what. With a heavy black coating, this sounds like it is getting fouled by oil. This can be caused by poor oil control due to worn piston rings, or it can be caused by leaky valve seals.
Aug 11, 2013 | 1992 Pontiac Grand Prix
Mirage lancer sparkplugs fouled and black
you have a weak spark. things to check is the ignition control module,spark plug wires
Dec 07, 2012 | Cars & Trucks
Mower won't start spark plug turns black
Black carbon fouling on the plug is a sign of the engine running too rich, start by replacing the air filter and plug and try again.
Jun 16, 2012 | Toro Power Lawn Mower
I have 2007 suzuki intruder the front spark plug was replaced 3 times due to intermitant spark.Each time i check the spark plug no spark then replace the plug then spark then runs for short period the No 1...
Fouling of the spark plug makes the exhaust extremely hot due to the burning of the fuel mixture inside the exhaust pipe and the spark plug end turn to black, fouling of the spark plug may be due to too rich fuel mixture check the correct setting of the air valve.
Jul 10, 2011 | 2001 Suzuki VL 250 Intruder LC
Plugs keep fouling out on my GL 1100
If any of the spark plugs are fouling out there has to be a carb problem. Are they black when you pull them? Are all of them fouled or just a couple?
If any of them are fouled then you are needing to clean and adjust the carbs.
Oct 29, 2009 | 1980 Honda GL 1100 Innerstate Gold Wing
Why do my spark plugs keep failing on my kawasaki 15 horse mower?
most of the time spark plugs foul out if you are getting to much gas they will turn black and foul out
Aug 31, 2009 | Garden
Yz 125cc 2003
Black spark plug means too rich , you will have to replace the spark plug since it has foul up and reset the air mixture screw on the carburator 2 and 1/2 turns outwards.
Check the air filter too.
Hope this helps.
May 23, 2009 | 2003 Yamaha YZ 125
Garden Logo
119 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
