Question about Philips TSU3000 LCD Touchscreen Remote Control
I have Philips Pronto TSU3000. It worked fine for 5 yrs. Now while the initial page shows, only the hard buttons work(volume,mute,etc). I replaced the battery pack with a new one and presed the reset to no avail. What am I missing?
    Problem Solver:
I tried a new battery pack, but the reset button performed the same way. Kaput
Posted on Dec 13, 2010
    Problem Solver:
  • 9 Answers
The touch screen commonly becomes defective. It needs replacement. www.servicewidetech.com
Posted on Dec 30, 2009
Pronto tsu3000 frozen
Check the remote control for its infrared emission. Check it with brand new batteries. If found faulty, clean the remote control's internal circuit board. Just click this link to know more about cleaning procedure. Pull up older posts there.
Sep 25, 2012 | Universal Remote Control Televison & Video
Audio Issues
have you tryed to reset the device, also performing a software update useing your desktop software might fix the problem.
Jun 16, 2008 | GPS
My philips srp5107wm/17 only changes the volume on my tv no matter what device i have it set on
The Philips remote is set to "push trough" the volume/mute to the TV for devices that typically don't have a volume function. Older versions of Philips remote used to allow you to select the device to push volume to, but for some reason this is no longer available (or at least I haven't found out how to). So here is the solution I used.
Teach (learning function) the remote to use whatever device you like for volume/mute.
1, Press the button for the device you would like to change
2. Hold down "learn" and the button you want to teach ex. "volume up" until the red light comes on
3. Place the original remote of the device you would like to change the volume on 5-10 cm away from your Philips remote and press "volume up" for this example
4. Repeat these steps for the "volume down" and "mute" buttons
5. Repeat these steps for other devices you would like to "push through" volume/mute to a device other than TV
Hope this helps others. I did find that some devices like SAT may not allow you to change the volume/mute, but otherwise this workaround does the trick.
May 05, 2012 | Philips SRP5107WM - Universal remote...
Thinkpad R51 Audio Driver
I had this exact same problem. Try this:
Above the keyboard are three hard keys for volume (down, up, and mute). The mute button only mutes, it does NOT unmute. To unmute, push the volume up button a few times. Now try your sounds again.
I was very confused because the hard mute key does not affect the GUI at all (you don't see the little speaker with the red x in the notification area). Hope this helps!
Jun 17, 2009 | IBM ThinkPad R51 Notebook
Printer takes ages to process
NV RAM and HD
To initialize NVRAM
1. Remove any installed accessories (for example, a stapler/stacker).
2. Turn the printer off.
3. Hold down the DOWN ARROW ( ) button, and then turn the printer on. Continue holding
down the DOWN ARROW ( ) button until all three printer control-panel lights flash once and
then remain on. This might take up to 10 seconds.
4. Press the UP ARROW ( ) button.
5. Press the PAUSE/RESUME button. The display should show SKIP DISK LOAD.
6. Press the UP ARROW ( ) button until NVRAM INIT is highlighted.
7. Press the SELECT ( ) button. The printer initializes NVRAM and then continues its poweron
sequence.
Hard-disk initialization
CAUTION A hard-disk initialization erases and reformats the printer hard disk. Perform a hard-disk
initialization only if an error code on the control panel indicates an EIO disk error. Always try
initializing the hard disk before replacing it.
NOTE Before performing a hard-disk initialization, print a menu map and a configuration page (see
Menu map and Configuration page). Use the information on the configuration page to reset
any customer-set printer configuration values that the hard-disk initialization procedure
changes.
To initialize the hard disk
1. Turn the printer off.
2. Hold down the PAUSE/RESUME button, and then turn the printer on. Continue holding down
the PAUSE/RESUME button until all three printer control-panel lights flash once and then
3. Press the BACK ARROW ( ) button. The display should show INITIALIZE DISK.
4. Press the SELECT ( ) button. The printer initializes the hard disk and continues its power
Mar 12, 2008 | HP LaserJet 2420 Printer
Cd/dvd burner
Check the volume controll on the player you are using. Players like Power DVD etc have volume controlls and mute buttons the mute might be active or the volume is down.
Dec 28, 2007 | Philips 20x DVD±RW Drive Burner
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Philips TSU3000 LCD Touchscreen Remote Control Logo
505 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
