Question about kawasaki Full Suspension Mountain Bike Men
I falled in water with my kawasaki.the bike was in the water 20 minutes end naw the engine not starting the bike is kawasaki zx9r ,2002
  • 29 Answers
Kick it over??!! ZX9 read the question!
Posted on Aug 11, 2009
  • 51 Answers
Let it dry out and kick it over a few times with the plug out. it should start fine when dry.
Posted on Aug 01, 2009
2000 ZX9R Bike overheating and the coolant comes out of the reservoir top line.
make sure that the thermostat is working and opening to let the flow of water in the engine, if it's ok you should start it and let it warm up and see if the cooling fan starts when temperature reaches close to 98 degrees, is it doesn't and the coolant boils then you have to change the temperature sensor as it is faulty.
Jan 15, 2014 | 2000 kawasaki ZX-9 R Ninja
02 ZX9 turns over but won't fire.
Hi, Erik and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
zx9r won start
What to do When Your Motorcycle Won Start
Kawasaki Ninja ZX 9R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Apr 06, 2017 | 2002 kawasaki ZX-9R
How to change oil on a 2002 kawasaki vulcan
Put bike up on center stand. Put empty pan below engine. Look under engine to find a bolt about 14, 15 or 16 mm. You will only see one so you can't make a mistake. Remove it and oil will drain as it falls out. Remove the oil filter on the front of the engine (down low, looks like a soup can with the end pressed against engine. You should have bought a new one already). You may need an oil filter wrench ($3 - 8 depending on store. Buy it at the same time as your filter so you get the right size). Oil will drip out, set it in the oil pan to drain. Then replace drain bolt and screw on filter. The remove filler cap on right side of engine. Add oil 10-40 or 20-40 weight usually ok this time of year. Add until you see oil mid-way in the oil level glass on bottom right of engine. Oil volume should be stamped near oil filler cap. Oil weight might be stamped on there too. Replace filler cap and start bike and run for 15-30 seconds. Turn off and let oil settle for a minute. Add oil as needed to get midway in sight glass. Repeat one more time. Check for leaks. Wipe everything clean so you can clearly see leaks when you check tomorrow morning. Good luck and dispose oil properly. Pep boys likely has the oil filter, just ask at the desk with your model and year. Cheers Clean up and dispose oil.
Aug 18, 2011 | 2002 kawasaki VN 750 Vulcan
GPZ 1000A1 1987 Fuel leaking into engine from number three Carb Tap not on PRIME. New genuine Kawasaki petrol tap repair kit fitted. has done this on two different sets of carbs ? Tried everything I know...
YOUR CARB FLOAT NEEDLE VALVE IS LEAKING. YOU WILL HAVE TO REMOVE CARBS AND CHECK. IT SOUNDS LIKE A NEEDLE VALVE IS DEFINETLY STUCK OR YOUR FLOAT IN THE CARB IS PUNCTURED
May 15, 2011 | kawasaki Ninja Zx7r Zx9r '94 To '04
Need to know if a 98 enign for my kaw zx9r would fit a 96 frame
It does not fit.Different rear axles and cylinder head bases.
Jun 09, 2009 | 1998 kawasaki ZX-9R Ninja
kawasaki Full Suspension Mountain Bike Men Logo
158 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Phillip Edwin
Level 1 Expert
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
