Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
SYSTEM NOT RECOGNIZING DRIVE
AFTER INSERTING DRIVE IT IS SHOWING NO ICON AND NO ADDITIONAL STORAGE DEVICE
  • 3,153 Answers
External drive not picked up on computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
What can i do? my jetFlash V85 is unknown
Connect your flash drive to your computer using an available USB port.
If your flash drive is not recognized, you'll usually receive an error that says "USB Device Not Recognized."
Click "Start" > "Control Panel" and open the system configuration by double clicking the "System" icon.
Navigate to the "Hardware" tab and click the "Device Manager" button to open the Device Manager.
Click the "+" next to "Disk Drives" and locate your USB flash drive.
A question mark icon should be shown to the left of the label.
Right-click the device name and select "Uninstall."
Open the "Action" menu at the top of the Device Manager and select "Scan for hardware changes."
This will scan your PC for any new devices.
Because you uninstalled the flash drive, it will be detected as a new device and the drivers will be reinstalled.
Click "Start" > "My Computer" and look for your flash drive.
If this process was successful, your flash drive should now show up under My Computer as a storage disk.
If its listed as an unknown device
Then right click on your flash drive select rename
Hope this helps
Nov 08, 2012 | Electronics - Others
My kingston 2 gb flash disk is not recognized, how can i fix it?
Please follow the below steps to fix your problem
Connect your flash drive to your computer using an available USB port. If your flash drive is not recognized, you'll usually receive an error that says "USB Device Not Recognized."
Click "Start" > "Control Panel" and open the system configuration by double-clicking the "System" icon.
Click the "+" next to "Disk Drives" and locate your USB flash drive. A question mark icon should be shown to the left of the label. Right-click the device name and select "Uninstall."
5
Open the "Action" menu at the top of the Device Manager and select "Scan for hardware changes." This will scan your PC for any new devices. Because you uninstalled the flash drive, it will be detected as a new device and the drivers will be reinstalled.
6
Click "Start" > "My Computer" and look for your flash drive. If this process was successful, your flash drive should now show up under My Computer as a storage disk.
Hope the above information will be helpful to you.
Thanks.
Oct 22, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I am trying to trasfer a large amount of files from my macbook to a dell laptop. The mac will recognize the drive and i am able to backup and save files onto it, however when i plug the drive into the...
The problem most likely is the Dell does not recognize the MAC file format (HPFS), but the MAC will recognize the PC's FAT 32 file system.
First format the USB mass storage device using the Dell, format this device in FAT 32 not in NTFS because the MAC can read and write/copy PC format files but the Dell/PC cannot read MAC format files.
Then Safely remove this device, connect it to the MAC and copy the files onto this drive. When you connect this device to the Dell, you will be able to see the files.
Have fun.
Aug 13, 2010 | Iomega Computers & Internet
Hello - computer recognizes the Cruzer sandisk however it won't open or run LaunchU3.
If you are using Windows.
Open the Windows explorer.
Plug the device in a USB port and wait for the computer to recognize it. After it is recognized the Windows Explorer will show two additional icons, one of them a CD-ROM.
Click the icon with the CD-ROM, and it will execute the U3 operating system. A small yellow icon with a U3 label will appear on the task bar. Right-click the icon on task bar and select the "Open U3 Launchpad". Point to the Settings button on the right side.
Right click that button and select the U3 LaunchPad settings
In the window that pop up point to "Autorun" button and click it.
Click the button that will say Enable.
After that it will launch automatically whenever the device is recognized by a computer.
If the U3 launchPad is missing from the device you can download it from the SanDisk site. Here is the link. Download it and install it on your computer. Note:It does not launch on MacProducts or Linux.
May 20, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I've got a Maxtor 300 GB shared storage device. My computer would not recognize the drive, so I figured I'd reinstall the software. Pressed the msssort icon rather than the install icon and now it won't...
Hi gogoc_da_man,
Take the CD out of the drive, and then reboot your system, then insert the CD again, and you'll get the install icon back.
Good Luck
Mark
Sep 17, 2009 | Maxtor (H01R300) 300 GB Hard Drive
Adding additional drives to an MSA20 unit,
1- Turn Off MSA and server
2- Insert new disks
3- Turn On MSA first then server
4- Access ACU and new HDD will be listed
Nov 21, 2008 | HP StorageWorks MSA20 (0808736947138) Hard...
Pen drive
Hi.
If you delete it in device manager and re-detect it, does it change? If you can see it in the taskbar, can you use the eject device icon to eject it, then remove and re-insert the drive?
Finally, try it on someone elses computer and see what result you get.
Mark
Nov 04, 2008 | Electronics - Others
CD/DVD thinks there's no disk in.
- mass storage device in = SD card.
- The DVD/CD can't recognize any type of disk inserted: Replace the CD-DVD unit, it is with problem.
May 02, 2008 | Computers & Internet
Mass storage device not working
transend pendrive not recognized
Feb 28, 2008 | Electronics - Others
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
128 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
