Hello Sir,
First you have to recall your memory, i.e; Was the handset ever dropped or get wet?, because this may cause the hardware to malfunction.
I will consider that you negate the above possibility, now the first thing is to check Volume Profile.
Try the volume buttons on the right side (as you face the device).
Look for the volume indicator while on the call and make sure it is all the way up
Press the green key, then press menu, select general options. Scroll down to default call volume and make sure it's set at 100%. (For assistance I have attatched a Snap Here)
You can also enhance the call audio by boosting the treble or bas.
If this thing is up to the mark already, then I'll Advise you to Upgrade you Device Software (Its Free and Easy)
The Official BlackBerry Device Software Upgrade goes here.
This will hopefully solve you problem,
If you got any more queries, don't hesitate to reply.
Regards.
Waqar.
I did what you suggested and still has the clicking sound. Should the volume indicator keep jumping up and down or should it stay still? Downloaded new software also.
Thanks
