Question about Sport & Outdoor - Others
Need inside top center part for Eastman Outfitter Hunting Blind
Eastman Outfitters Carbon Venture Magnum Blind hub to hub 89''x89'' inside the tent the center part that connects the rods is broken.
two rods have broken off in the center part.
I think I need a new center part with 4 new rods but don't know where to order it from.
Model 9640CR
the box has this website: www.eastmanoutfitters.com
but it is down
Where can I buy Big Cat 350 Hub Blind at reasonable rate?
You can have a look at Hunting Blinds as this is one of the best website that is well known for providing one with the best options available for providing one with the best options. I too have used this website for purchasing hunting blinds and came out with the best results for providing one with the best options for oneself.
Apr 01, 2017 | Big Video Game Consoles & Games
Where can I buy waterproof hunting blind with a mesh window?
There are many websites that deals with the hunting blinds that may provide you with the options that are there for providing one with the best suitable options for oneself. But the one that I prefer the most is
Best Deer Blinds 2017 Buyers Guide for Hunting Blinds as it provides us with many helpful options that are best for oneself. This website is best because it provides us with the best options for comparing the different brands and then choose the best options among them.
Apr 01, 2017 | Hunting
Instuctions for 13×9 cabin tent sleeps 6 wmt-1390 (not instant)
OWNER'S MANUAL WARNING: KEEP ALL FLAME AND HEAT
SOURCES AWAY FROM THIS TENT FABRIC.
This tent meets the flammability require-
ments of CPAI-84. The fabric may burn if left
in continuous contact with any flame source.
The application of any foreign substance to
the tent fabric may render the flame-resis-
tant properties ineffective.
DO NOT...
1. Do not pitch tent near an open flame.
2. Do not leave campfires unattended.
3. Do not allow CHILDREN or ADULTS
to use lighted candles, matches or
other flame sources in or near tents.
4. Do not use heating, lighting or
cooking equipment with open
flames in or near tents.
5. Do not use fuel burning/oxygen
consuming devices (i.e. heaters,
lanterns, or other flame sources)
inside your tent at any time.
6. Do not use other than recommended
water repellent compounds on your
tent.(See:"Seal the Seams")
7. Do not spray the tent with insecticide.
8. EXTREME CAUTION: Never use any
fuel burning/oxygen consuming
device, or any device that produces
fumes (including stoves, lanterns,
candles, hibachis, or heaters) in or
around your tent. Inhalation of fumes
may result in carbon monoxide
poisoning, injury and/or *****.
DO...
1. Always extinguish campfire before
leaving area.
2. Exercise care when using electricity
and lighting in and near tents.
3. Disassemble and store tent properly
after camping to ensure the tent's
longevity.
4. Always use a hammer/mallet when
driving stakes into the ground. CARE This recreational item is not intended for
use as a permanent structure, as fabric
will quickly degrade if exposed to UV
light. No (sun shelter, screenhouse, tent)
can withstand prolonged exposure to
sunlight. UV damage is not covered under
the limited 90 day warranty.
Structural Integrity
Although our tents and screenhouses are
constructed to rigid specifications, periods
of wind or rain soaking the ground may
loosen the stakes and cause the uprights to
sink into the ground. This will weaken the
rigidity of the overall structure. Water pock-
ets may also form in the roof if the unit is
not assembled taut, the weight of which
may cause broken frames and torn fabric
Storage
Tents/screenhouses must never be rolled
up or packed while damp, as mildew will
form within a few days. Allow tent to dry
completely before rolling and storing.
REPLACEMENT PARTS Always mention the Model number in all correspondence regarding your tent and when ordering
replacement parts. ASSEMBLY INSTRUCTIONS Lay Out the Screenhouse and Poles
Select a smooth, level site and spread out your
screenhouse.
Sort the poles by number and connect the
sections together. See diagrams below for
numbering
tep 2 - Install the Poles
Insert the ends of each of the three roof poles
into the 3-way hubs
Insert the four side roof poles into the 3-way
hubs. See Diagram 2 Insert the leg poles into the hubs to raise the
screenhouse frame. Make sure that the pole
end with the holes in the sides (
down. See Diagram 3
Secure the Screenhouse
Drape the screenhouse body over the frames.
Hook the S-Hooks
located at the bottom of the leg poles.
L
Wrap the velcro tape
screenhouse, around the poles to secure them.
When the screenhouse is in its proper location,
stake it down by driving stakes through the
four D-rings
Step 4 - Install the Guy Lines
Tie the loose end of a guy line through D-ring
Repeat for the other three guy lines.
1B
Make a loop at the end of the guy line with the
L
slider. Stake the looped end of the line out
about 3' from the base of the pole. Adjust the
slider until the line is taut
C
Sep 28, 2016 | Sport & Outdoor - Others
Looking for instructions to put up a Cabelas Outfitters Series Deluxe Alaknak Vestibule 12x12 tent
Try their website. Because unless it is a computer you have asked in the wrong section.
Aug 04, 2013 | Computers & Internet
What is a hunting screen for on a hunting blind for?
The screen on a hunting blind allows the hunter to see out but it shields him from view from the target.
Jan 14, 2013 | Hunting
I need pitching instructions for a Great Outdoors Apollo 4 man tent
Take out all poles and stakes and tend and seperate.. First lay tent on ground and streatch out where you wish to pitch the tent. Then take stakes and place them in the four corners of tent through the loops so ththat when you hammer in the stakes the tent is nice and stretched out tightly. There should be two more loops on each side int the middle. When the tent is secure to the ground, take the poles that should have been put together and feed them through the hoops of the tent on the sides and top. Leave the top center parts of poles apart until you have poles through rest of loops and attatch them at the top of tent. front, back and center usually work pretty good for order. Doint middle last because it is the highest point. Hope not too confuseing. I camped a month every year for many years. You never forget.
Dec 23, 2012 | Sport & Outdoor - Others
Is it safe to use a gas (propane) fridge inside a tent
it is not safe to use your 'gas'/'propane' stove inside your tent --- it puts off carbon dioxide and you can't smell it or see it and it fills up small spaces very fast and it CAN kill you. only use it outdoors or if you have a exhaust tube that exhausts to the outside.
c...
Jan 17, 2011 | Sport & Outdoor - Others
My tent has served me well but recently parts are starting to fall off. When I shake the outer cover dry there are lots of flakes that look like glue. 3 of the velcro attachments to the outer part of the...
Hi, the flakes you're referring to is the original weatherproofing that was applied by the manufacturer. This coating can be reapplied using a spray on product that is purchased at most camping outfitters. Before you spray, give the cover a gentle wash to clear any dirt and grime. Then using a mild abrasive pad, gently lift away the flaking weatherproofing. Spray the new coating as per product instructions.
Nov 17, 2010 | The North Face Tadpole 23 Tent
Just purchased mossberg 935 used gun from cabelas and was told it should shoot 2 3/4 inch shells with no problem,took it hunting shot 2 3/4 bb and T loads and it will not eject, is there something that I...
Hows it goin-
From what I understand, the 935 is a Magnum gun. Therefore it will have some ejection problems with the lighter loads. Ive also been told by multiple people (I am a Firearms Outfitter at Cabelas, Idaho) that the 930 and the 935 are prone to jam... a lot. Personal experience, none....but I talk to a lot of die hard gun users daily.
Also known to be problematic on this firearm are some of the plastic parts on the 935 breaking, namely the forearm retainer and or the pusher assembly. Someone else is bound to speak up here, but I would think your best bet is to jump up to some 3in shells. Hope it works out for you.
Check out Cabelas Website in the "Chat Forum" section. There are some good discussions about your firearm.
LINK TO SITE
Oct 17, 2009 | Mossberg Sport & Outdoor - Others
Sport & Outdoor - Others Logo
331 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
