Question about Refrigerators
Makes clicking noise
Makes continuous clicking noise.
  • 294 Answers
Clicking noises are generally caused by loose parts (such as loose condenser coils or compressor "tubing rattle") or rollers and feet that sit unevenly on the floor.
Look for any part that is loose. Then remove the bottom trim piece by lifting it off its supports, and check the feet at the front of the unit. If necessary, turn the adjustable feet up or down so they contact the floor squarely.
have a good day!!
Posted on Aug 01, 2009
2008 explorer starts with jump, shut off will not restart, clicking noise
clean battery posts and cable ends and make sure to tighten securely when done
Aug 31, 2014 | Ford Explorer Cars & Trucks
Has clicking noise on right pull wheel
Clicking noises from the drive wheel area usually means the gearbox on that side has a minor to a more severe issue. Call the place where you got the chair. I'm glad it's running and it could continue to run even with the clicking noise. It could be something as a loose hub nut on the wheel or something rubbing when you are making a turn.
Dec 23, 2013 | Electric Jazzy 1115 Power Wheelchair
95 buick regal two fans in front , one make clicking noise after vehicle turned off. Its continues to spin and makes a clicking noise after turning off engine
It is normal for the fan to stay on after the engine is off. The clicking is not. Once the negine is cooled down and the fan is not running. check the fan by spinning it and try to locate the clicking noise. Make sure the fan doesn't wobble. If it does then the bearings are going out, replace the fan. The clicking could be something lodged in the shroud, clicking against the fan blade. Like a stick.
Jul 01, 2011 | Buick Regal Cars & Trucks
Kenmore electric dryer Model #66512692 makes a clicking noise when push start. Cleaned out so there is no air blockage and still will not start.
Hello & Welcome to FixYa
When the Thermal fuse of the dryer goes bad it wont turn on or will make clicking noise as it is doing right now. You can check the thermal fuse for continuity, if it is open then the thermal fuse needs replacement however, if the fuse tests continuity then check the control board (if that is bad then it needs replacement). Please get back to me if you have any other questions.
Kevin
Dec 27, 2010 | Kenmore Dryers
When turning it makes loud noises and is harder to turn, but there seems to be enough fluid in container.
Does it make a clunking noise when turning? How about a continuous clicking noise when turning? That would be tie rod end if clunking, or cv shaft (ball bearings) if continual clicking when turning. Sometimes turning very sharply can put to much pressure on the power steering pump and strain on the belt when turning. Do check your steering linkage and make sure nothing is rubbing against the tire when turning.
May 29, 2010 | 2001 Chrysler Town & Country
Bad axle
A bad axle will make a continuous clicking or clunking sound when making a sharp turn (left or right), but if they are really worn out it would not have to be a sharp turn for them to make that noise.
May 11, 2010 | 1996 Dodge Stratus
Tv just makes clicking noise and doesn't turn on
I had the same problem. The power board for the on-off had to be replaced. The set is only 11 months old.
Oct 19, 2009 | Philips 42PFP5332D 42 in. Plasma...
My phillips 50'' plasma tv is making a clicking noise like it is turning on but does not come on and continues to make the clicking noise. Any comments on what the problem could be?
sounds like its the CCFL trying to come back on, either that or like on my sony Bravia when it selects input sources it makes a clicking sound as well.
1) is got a bad CCFL
2) it has a bad psu
3) if its under warranty take it back
Sep 04, 2009 | Philips Televison & Video
My Hitachi PJTX300 projector - Clicking noise
hi,
have you solved the "clicking noise" problem yet?
i think i have the same problem with my pj-tx300.
Thx in advance for your answer. :)
Aug 23, 2009 | Hitachi PJTX100 Multimedia Projector
Kodak EasyShare lens makes clicking noises
try going into the menu 8 clicks down onto theaf control,and make sure its on single AF ,not continuous,as if its on continuous it will keep trying to stay in focus,if this dosent solv it its probabley a faulty lens
Jan 08, 2009 | Kodak EasyShare V1003 Digital Camera
Refrigerators Logo
179 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
