Question about Dryers
Gas dryer flame comes on for 10 to 20 seconds and shuts off every time?
    President:
  • 1,714 Answers
Sounds like the flame sensor. Do you know how tho change it?
Posted on Aug 01, 2009
I have a gas dryer, model MDG7657AWW that will not stay heated. Every time I put it on, the flame comes on for about 21 seconds & then shuts off. I replaced the igniter, hi limit thermostat, cycling t
On a gas dryer the heat normally only comes on for 30 seconds or until the drum temp reaches 160f at which time the flame is shut down by the cycling thermostat. The drum temp then starts to drop. When the drum temp reaches 105f then another blast of heat is issued for 30 more seconds.That is how they work. Put it all back together and trow a load in there.
Oct 28, 2011 | Dryers
I have a older Maytag gas dryer DG612. The igniter comes on the gas lights, runs for about 5 seconds then shuts off. The process repets its self over and over again. It is trying to start but shuts off the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 16, 2010 | Maytag MDG7600AW Gas Dryer
80 series kenmore gas dryer. Won't dry clothes. Igniter glows, gas valve opens, flame lights. Stays on for about 45 seconds then flame shuts off. About 1 minute later it lights again but it doesn't stay on...
Did you get a solution yet? - our dryer is doing the same exact thing....last time it was not lighting at all and we found out it was the thermal fuse - very cheap fix...this time the symptoms are exactly as you described.
Aug 03, 2010 | Kenmore Dryers
The gas dryer is not getting hot enough to dry clothes have to run it double the time to get clothes dry-exhaust not blocked-igniter is working-there is a flame-checked dryer heat setting manual knob with...
You might want to replace the thermacouplar. Sometimes when they are going out , all will appear to be alright but as you stated it takes a long time for the flame to come back on. This sounds to me like the thermacouplar is going out.
Dec 08, 2009 | Amana ALG331RAW Gas Dryer
Kenmore dryer
ok im still with you ,,,,now what i need you to do is start dryer and listen to the gas vavle ,,it will click once than a couple of seconds it will click again,,than you should hear the gas light,,now your at left corner listing,,if you have no clothe in dryer the flame should stay on about 3-5 mintues..after the dryer heats up and shuts of it should come back on in about the same time 3-5 mintues,,listen for rattling or not clicking open the second time around,,if this is the case replace dryer vavle coils,,keep me posted,,onthejob..if the ignitor sensor were bad it would not light at all.they rearly go bad...
Jan 10, 2009 | Kenmore 63942 Dryer
GGW9868KL0 SENSEON GAS DRYER Flame comes on but clothes not dry
since you know your stuff and our exhaust is clear correct,,,change your gas vavle coils ..if weak they will shut unit down in a couple of mintues..
Dec 20, 2008 | Whirlpool LGV4634JQ Gas Dryer
Flame shuts off after five seconds
HI! I BELIEVE THE PROBLEM YOU ARE HAVING IS CAUSED BY A PART CALLED THE THERMOCOUPLER. THIS IS A SAFETY DEVICE THAT SHUTS OFF THE GAS IF THE FLAME GOES OUT, BUT IT NEEDS HEAT TO MAINTAIN THE PROPER CIRCUIT. THIS MEANS THAT THE THERMOCOUPLER IS BAD AND NOT HOLDING THE GAS VALVE OPEN AS IT SHOULD. IT IS A SMALL THIN ROD TYPE THING THAT WILL BE VERY CLOSE TO THE PILOT OR IGNITER AND IT HAS TO FUNCTION PROPERLY TO ALLOW THE GAS TO CONTINUE TO FLOW. WHAT IT IS DOING IS GETTING JUST WARM ENOUGH TO OPEN THE GAS VALVE, BUT THEN THE IGNITER STOPS AND THE BAD THERMOCOUPLER COOLS AND TURNS YOUR GAS OFF. YOU NEED TO REPLACE THE THERMOCOUPLER AND YOU SHOULD BE BACK TO WARM CLOTHES IN NO TIME. HOPE THIS HELPS YOU. ANY QUESTIONS, JUST REPLY AND I'LL HELP MORE.
ARCLIGHT1217
Nov 02, 2008 | Maytag MDG2706A Gas Dryer
KENMORE gas dryer
Hi .No The Solenoids Are Turning The Gas On . I would Check The Venting . Remove The Venting Clean All Venting. Thanks The Appliance Doc
Oct 03, 2008 | Kenmore 73952 Gas Dryer
Gas dryer
hi. no not now. i would check the venting. clean the venting. thanks the appliance doc
Oct 03, 2008 | Kenmore 73932 Gas Dryer
Very long drying time
ck vent system if vent not oper it can cause flame roll out and shut off unit also ckd flame sensor on side of burner
Jun 01, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
82 people viewed this question
Top Dryers Experts
