Question about Panasonic KX-TGA600B Cordless Expansion Handset
Can't register Panasonic KX-TG6051 handset
Bought this handset off Amazon in order to expand my base system but it came to me registered as Unit 2 of another system. Tried the deregister Menu,002,335, OK, but it does clear the handset, I assume becasue it cannot reach its original base system.
Is there any way I can make this phone reset to clear?
Press (menu 00, reg) an press locator for 3 secons--- than press ok in you phone.
Posted on Sep 29, 2009
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
May 30, 2017 | Panasonic Lands Phones
Registration of phone to main phone
The come pre-registered to the Base Unit.
If for some reason it has not been registered base unit consult page 26... Of your OWNERS Manual The owners manual describes invoking code 130 .
if you not have your users/owners manual you can get a copy online... (see url, below).
http://ep.yimg.com/ty/cdn/yhst-86993463860622/KX-TGC212S.pdf#_ga=1.158670974.574155064.1461252188
Apr 21, 2016 | Panasonic NEW Expandable Digital Phone...
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
How do i sync my panasonic phones cordless kx-tga810
335 is the magic code when you want to remove a previous handset or base station registration!
Handset:
1 " (middle soft key) i L i #
2 Enter "335".
3 "Cancel Handset" i #
LThe numbers of all handsets
registered to the base unit are
displayed.
4 Select the handset(s) you want to
cancel, by pressing the desired handset
number. i #
5 "Yes" i # i {ih}
Base Station:
A handset can be registered to a maximum
of 4 base units. A handset can cancel a base
unit that it is registered to. This allows the
handset to "forget" the base unit.
1 " (middle soft key) i N i #
2 "Registration" i #
3 Enter "335".
4 "Cancel Base" i #
5 Select the base unit(s) you want to
cancel, by pressing the desired base unit
number. i #
6 "Yes" i # i {ih}
Dec 23, 2013 | Panasonic KX TGA810 1Line Cordless...
My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, re-register the handset.
1 Handset:
{MENU}
2 {V}/{^}: "Initial setting"
{OK}
3 {V}/{^}: "Registration"
{OK}
4 {V}/{^}: "HS registration"
{OK}
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
tone)
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
registration tone sounds.
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
Note:
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
See http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF (page 22)
Dec 06, 2011 | Panasonic KX-TG1033S Cordless Phone
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
The included handset and base unit are
preregistered. If for some reason the
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
Panasonic KX-TGA600B Cordless Expansion Handset Logo
793 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
