Question about Sony DVP-NS305 DVD Player
Just comes up in Black and White - Sony DVP-NS305 DVD Player
  • 158 Answers
CHECK COLOUR SYSTEM- SHOULD BE SWITCHED TO PAL
Posted on Aug 03, 2009
I had the same prob-turned out it was just loose/bad av leads connecting to tv and a little fiddle corrected the prob, eventually replaced cord-solved.
Posted on Jun 12, 2011
Color pictures in color come from the printer in black and white
u need to change settings on the printer from black n white or printer settings in windows is set to black n white. even your graphics software could be set to black n white. normally its windows or on printer itself in configuration settings
Oct 19, 2014 | Kodak Office Equipment & Supplies
I have a red, a white, and a black coming from the ceiling. coming from the fan i have a black, white and black and white striped. is it white to white, black to black, and red to striped?
Yes that will work just fine. black and red are hot lines from your switches. if you prefer a certain switch to do the light vs. fan then you must verify what color is coming from the wanted switch.
Jun 26, 2011 | Hunter Heating & Cooling
I have a used ceiling fan that I want to install. I see only three wires coming out of the top; a black, a white, and a blue. The fixture has the fan and 4 lights attached. Can you tell me how to...
Black is the hot wire, white is the neutral, and blue is the hot wire for the lights. If you only have a black, white and green(ground) coming from the electric box in the ceiling, you will have to wire the blue and black together coming from the fan and connect them both to the black coming from the box. The white will connect to the white coming from the box in the ceiling. You should have a ground wire off of the fan. If not look for a ground screw on the fan down rod. The ground is for safety.
Apr 08, 2011 | Heating & Cooling
Only have two wires to connect to
What timer are you installing?
Intermatic battery-operated timer with red, blue, black and green
Green connects to bare ground
Red is capped off.
Blue connects to one wire
Black connects to other wire
Push on-off button: if light comes on, timer wiring is correct.
If light does not come on, then reverse blue and black wires.
Other in-wall timers except Aube have red, black, white and green
Green goes to bare ground
Red connects to one wire
Black connects to other wire.
White: in back of electrical box are white wires twisted together and covered with wire nut. Connect white white to these other white wires.
If box does not have white wires described above, then connect white wire to bare ground along with green wire.
Push on-off or override switch: if light comes on, timer wiring is correct.
If light does not come on, then reverse red and black wires.
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Dvd coming up black and white on new plasma
why does my movie come out black and white on my dvd player
May 28, 2009 | Hyundai ImageQuest HQP501HR 50 in....
Where do wires connect???
Black is neg, Red is pos, and White is neutral or ground.
Apr 30, 2009 | Microwave Ovens
Trying to hardwire my mini fridge in my popup. I have a blue and a gray wire coming from the condenser and a black and a white wire coming from the thermostat control, and a white and a black wire coming...
ok the black wire from the powersource goes to the (-)negative terminal in the converter, the white wire goes to the (+) positive.
From the converter the white wire goes to the white wire on the termostat.
the thermostat black wire goes to the grey wire on the condenser
the blue wire on the condenser goes to the black wire on the Conveter.
Mar 27, 2009 | Refrigerators
Ceiling Fan Electric
hi,
you may have two dedicated ceiling fan circuits coming out of that box, check to make sure theres not a black wire bunched up in the ceiling or cut off, or try this
1.white to white wires, and black wire and black with a white stripe to red wire out of ceiling for fan and light together operation
2. If you can find the black and the red and the white coming out of the ceiling then you may have two switches on the wall for that fan, red for black fan wire, black with white stripe for the to black out of the ceiling , white all together. try that combination
for separate light and fan control from the wall
good luck, and be careful
J
Aug 06, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Wiring-
The ceiling has Black and white (dirty I expect) ,
black is hot , white is neutral
the green is ground ( the fan will ground through the mounting screws)
so connect the black to black (hot)
as you have only one choice left that is the blue/white to white.
I assume you have a strong bracket and a fan was existing previously in this spot. If not you have to install a new fan support and wiring box.
Jan 26, 2008 | Universal Remote Control Hampton Bay...
Sony DVP-NS305 DVD Player Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
