Perhaps the owner's manual will be useful:
ELNA 2130 Manuals
SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
SOURCE: No "Zig" to my "Zag"
I Love the support Brother gives!
Here's what Brother says about the Zig zag issue.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faqh/000000/000000/000018/faqh000018_000.html?reg=us&lang=en&c=ca&prod=hf_xl5130eus&page=FaqEndPage
your manual (download)
http://welcome.solutions.brother.com/BSC/public/us/ca/en/model_top/HomeSewingMachine/hf_xl5130eus.html?reg=us&c=ca&lang=en&prod=hf_xl5130eus
SOURCE: only does zig zag stitches, no straight stitches,
make sure the pattern selector is set for straight stitch first. If it is set correct then the machine may be "stuck" is zig zag mode. May need to be de greased and then re lubricated.
SOURCE: ZIG-ZAG NOT WORKING
Make sure your presser foot is tight down. If the needle is going from side to side, it's doing it's job. If the stitches are coming out straight, the material is probably slipping back and forth to center area. The presser will eliminate this.
