Question about Welding Tools
Need to get Timing specs
I have a welder that I need to get the timing specs for ASAP any help I can get from anyone will be so greatly appreciated.
Need timing specs for:
Lincoln Ranger 10 305 with Kubota motor
Thank you for help
JoAnn
    President:
  • 1,714 Answers
What exactly is the problem? Is the engine not running? Or running rough or what?
Posted on Aug 01, 2009
I fouled up the timing on my 1990 Subaru Legacy Wagon. Tried resetting it to the factory specs but it still wont start.
You have not set it to the factory spec, and its probably 180 degrees off. Rotate the crank to top dead center (the mark on the crank toothed pulley, align the cam timing marks, refit the belt THEN release the tensioner. Rotate the engine manually to verify that all the timing marks realign themselves.
Jan 19, 2014 | 1990 Subaru Legacy
Need Help asap
did you set the belt timing right it is a interferance engine and will bend valves
Jun 21, 2012 | Cars & Trucks
2008 Yamaha TTR 110e need timing specs
Hi, Pierce_602 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.miniriders.com/ask-the-tech-masters-/37232-110cc-timing.html
Setting valve clearances and timing couple of questions
2009 YAMAHA TTR 110 SERVICE REPAIR MANUAL PDF DOWNLOAD Download Manuals... $10
OEM parts for Yamaha
YAMAHA TT R110E Owner Manual
Jun 01, 2011 | 2008 Yamaha TTR110E
Timing
1992?? pump should fire about 12/16 degrees before TDC but you should have timing marks .just noticed turbo,reading question again go for 16 ,you should have timing marks anyway ,and the pump has a 8mm hole that lines up with backplate if i remember correctly
Aug 21, 2009 | 1992 Volkswagen Jetta
Need timing specs and point gaps please
Well I can't really help with the timing specs but the points gap should be .019 (in.), but I always learned to use a match box to gap them  and that works great too. Hope this helps.
May 06, 2009 | Pontiac Grand Prix Cars & Trucks
2002 kia sportage timing specs.
Check with auto zone or auto advance they help me help all the time
Feb 04, 2009 | 2000 Kia Sportage
99 dodge caravan 3.0 water pump
it is located on pass side behind timing cover the timing belt runs the water pump so the timing belt will have to come off this is a big job!
Feb 01, 2009 | 1999 Dodge Caravan
Timing
Then, the smog tech either does not know how to set base timing on your car, or he is trying to sell you something that you do not need. Base timing involves a procedure that requires a tech to utilize a set of pins to the ECU, and are jumped together. You cannot hook up a timing light, and get the correct timing reading without knowing which pins to use. Hope this helps; thanks for choosing FixYa to answer your question. The graciousness of a FixYa rating would be greatly appreciated.
Jan 12, 2009 | 1994 Toyota Camry
Chain
Go to any reputable shop/mechanic; you probably need a new chain and/or sprocket...OR Possibly just a chain adjustment. Don't wait around, do it asap, I wouldn' t play with this particular problem.
Nov 20, 2008 | 1990 Suzuki RGV 250 L
Welding Tools Logo
197 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
