Question about HP OfficeJet Pro L7580 InkJet Printer
Hi I have a HP Officejet L7850 Printer with a "Rear Door is Open" error. I have checked the rear door and I do see the contacts on the door is damage and can not make a proper connection with the sensor. Can I bypass the sensor?
  • 26 Answers
Please follow the steps given in the below document and check if it resolves.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01626835&cc=uk&lc=en&dlc=en&product=2512008
Wish
Posted on Aug 01, 2009
Hi I have a HP 6310 and it keeps saying there is a paper jam, but I cant see any in there. Any ideas
Turn off the printer.
Open the rear access door.
You need the clean the rubber rollers with lint free cloth. There could be dust particles stuck on the rollers. Cleaning it with lint free cloth ( clean upwards exactly like the rollers roll after picking up the paper )
Close the rear access door firmly.
Check if the error message goes off.
If you still find the error message, follow the steps below :
Disconnect the power cord from back of the printer ( while the printer is powered on )
While holding the # and 6 key on keyboard, connect the cord back.
The printer will go through alignment process. Complete the alignment.
*Note : Doing this reset, you will loose any fax logs or settings set on printer
The printer should work fine. If the issue does not resolve, it could be hardware issue.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 30, 2010 | HP Officejet 6310 All-In-One InkJet...
What E means for hp deskjet 2200 problems?
Well 'E' means 'Error', it represent error like - E:461, what is the error in your printer screen? Post further information for detailed solution.......
Good Luck!!
Thanks for using FixYa!!
Jul 06, 2010 | HP Business Inkjet 2200 Printer
PRINTER MAKES A LOUD SOUND LIKE A MACHINE GUN WHEN IT PRINTS
Turn off the Printer
open the Front access Door, Check if there is bits of paper or dirt on the ROD that moves the Cartrige/carriage.
Move the Carriage freely 5-6 times from left to right ( it should move smoothly )
Remove the Cartridges, Clean the contacts on the Cartridge ( golden Contacts)
Open the Rear Access door, Clean the Rollers with lint free cloth.
Close the Rear access door and front door
Power on the Printer. If the grinding noise continues, Unplug the power cable from back of printer ( while printer is on ) and while holding the # and 6 button, connect it back.
It should go thru alignment process and the grinding noise should be gone. If it doesnt, probably.. its time for new printer of HP again.
Jun 24, 2010 | HP Officejet J5780 All-In-One InkJet...
My officejet 5610 says "carriage jam. Open Door etc. I can't find a door to the carriage.
Hi!
here are some solutions for your carriage jam error.
1. Clear any jam...remove loose paper.
2.Clear the jam from the back of the printer
turn off the printer...remove the rear access door..
pull the paper out of the roller and return the rear access door.
3. Clear the paper jam from the front of the printer..while printer is on.. open the carriage access door..
disconnect the power cable from the back.. remove the paper output tray.
look inside the product..check for torn papers..gently pull out the paper from the roller...return the paper output tray and the carriage access door. plug the power corn and turn on..
4. Make sure the carriages move freely...while the printer is on.. open the carriage access door.
disconnect the power cord from the back..remove the paper output tray...look inside if the carriage is stuck and if there is no papers or object that restrict the carriage to move..return the output tray.. return the carriage access door...
And lastly after doing this steps try to reset the printer and try to print..
To reset the printer....press the power button to turn on the printer..disconnect the power cord from the product..disconnect the power cord from the wall outlet.. wait for 15 seconds.. plug the power cord to the wall socket....plug the power cord at the back of the printer.. press the power on of the printer.. try to print the test page...
Good luck! hope this solve the problem
Much appreciated if you rate this help.. thanks
May 23, 2010 | HP Officejet 5610 All-In-One InkJet...
Hi I have a HP Officejet L7850 Printer with a "Rear Door is Open" error. I have checked the rear door and I do see the contacts on the door is damage and can not make a proper connection with the sensor....
You can but that means stripping the printer to get to it. If it is optoelectronic then just push a small piece of card(black) into the slots. If it is a mechanical switch then do the same by pushing the lever down of the switch by jamming the paper into it. This is a temporary fix only and you should really just replace the door assembly.
Aug 01, 2009 | HP OfficeJet Pro L7580 InkJet Printer
I am experiencing the same problem.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab56
Jun 30, 2009 | HP Officejet 5610 All-In-One InkJet...
Says Paper Jam But No Paper In It
Hi
Paper jams can be real or false. The unit may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same. WARNING: Jammed paper must be removed using the rear access door and the power cord must be disconnected or a carriage jam or mechanical damage may occur. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 1: Removing the rear access door bd842f6.jpg
  4. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
  5. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to buy on this page to order replacement parts.
  6. From the rear access door opening, remove the jammed paper.
  7. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  8. Reinstall the rear access door.
  9. Reconnect the power cord to the unit and turn the unit on. If a carriage stall occurs after clearing the paper jam, resolve the carriage stall.
Preventing paper jams The following information will help prevent paper jams from occurring:
  • When loading paper in to the paper tray, push it in until it meets first resistance. Do not continue pushing the paper in. If the paper is pushed too far in, more than one page is picked and paper jams result. This is the most common cause of paper jams with the HP Officejet 410 series.
  • Never use paper that is wrinkled or damaged in any way.
  • If you are having problems using paper that has already been printed on once, replace it with fresh paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door isn't locked.
  • Every six months - one year, clean the paper feed rollers with a rag slightly dampened with clean water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | HP Officejet 4110 All-In-One InkJet...
"Door Open" error message
check all the doors of the printer. If they are not closed, The printer will continue to throw this error.
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
Rear access panel open
open the rear panel, check all path is clear. close the rear panel, mkae sure that the sides of the rea panel is locked in place. there is micro switch that detect the door panel. if the door is close correctly the micro switch os actived then you will get the error.
Jan 05, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Printer won't release patper after printing
Print a self-test page from the unit to verify that it is working correctly. On the unit front panel, press Setup, press 1, and then press 5. CAUTION: Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit. Turn off the HP product and turn it around so the back of the unit faces you. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 2: Removing the rear access door Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts. From the rear access door opening, remove the jammed paper. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray. Reinstall the rear access door. Reconnect the power cord to the unit and turn the unit on. Ray
Jun 18, 2007 | HP Officejet 4215v All-in-One Printer
HP OfficeJet Pro L7580 InkJet Printer Logo
344 people viewed this question
Seeker5211
Seeker5211
