Question about DEI Python 1400XP Remote Start/Keyless Entry System
I have a toyota camry station wagon 1995 with I believe to be a your valet alarm. I have a new remote for it because the original one broke. This remote won't work the the alarm or the keyless entry to my car. How can I program the remote? Unfortunately this was a used car when I bought it and didn't come with any instructions for the alarm. The new remote has 68 billion rolling codes, FCC# EZDEI491. It has 2 gray buttons and it flashes red.
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
  • 22 Answers
SOURCE: Valet 712T keyless entry works inside vehicle only!
Two suggestions one even if its a new battery change it ,secondly if your new car has metalised window tinting on it and your old car did;nt this can be the reason also ,if so move the antenna to the front screen which won;t have tinting.
Posted on Apr 21, 2009
  • 103 Answers
SOURCE: I have what i believe
There is a green and blue wire on a white colored harness. You will need to verify that these wires are connected to the lock and unlock wires in the vehicle. This green and blue wires are on a 3 pin harness plugged into the alarm.
Posted on Aug 21, 2010
  • 1455 Answers
SOURCE: So I have a viper alarm system in my car and
You have to turn off your ignition and immediately press that 'eraser like button'(valet switch) for a second and release it. Alarm will then come out of valet mode and your remote should work, if it's good.
Posted on Oct 08, 2010
  • 22 Answers
SOURCE: I lost my keyless for
turn the key to ON, then press and release the valet/program button once, then press and hold. The 561R LED will begin to blink. While you're holding down that button, press and release lock on the remote. Turn ignition off and try it out.
Posted on Mar 07, 2011
I have a prestige remote Audio box starter remote alarm on a 2002 Toyota Camry.I unplugged the sensor and the car still doesn't start.can you help me i am out of the state need to get home.
Locate the valet switch( black push button), turn ignition on, press and release valet switch. the valet switch is plugged onto the main control unit. You can find the main control unit by tracing the harness that you unplugged from the shock sensor. The valet switch is plugged into a two pin plug and has a blue end. Trace the wire to the valet switch.
Jul 10, 2011 | Prestige Remote Start
How to programme a clone keyless remote for 95 Toyota camry XLE Thanks
1 turn ignition to "on"
2 insert original remote into reader located in the glovebox
3 red security light should come on solid
4 insert new remote into reader straight after taking out old remote
5 new remote is now programmed
Jan 19, 2011 | 1995 Toyota Camry
I had to change the battery. After replacing the new battery all systems work, but the car won't turn over and the factory alarm is blaring. How do I disable the factory alarm? I do not have the...
If you have the Toyota factory alarm, there should be button under the driver's side dash to reset the alarm....Look for it 1st, then read below.
Put the key in the ignition, and turn forward
all the way just before cranking, to the ON position.
Then within 5 seconds, locate, press and hold in the
valet/overide button, found under the
dash area, (push button, spring loaded)
until the installed LED (the blinking light)
in your dash area goes on solid,
and the siren chirps once.
(Your valet switch might be the toggle
(on/off) type. in this case, key on,
flip switch in opposite direction,
then turn the key off.)
This should reset the alarm, and reset
the grounded relay on the starter wire,
allowing you to start the engine.
At this point, the only thing working would
be the keyless entry from the alarm,
if it came equipped that way.
Just Repeat these steps to place it
back to usable armed mode.
You may get 2 chirps, confirming it,
and the lights may flash twice as well.
GL,
Td
Aug 10, 2010 | 1997 Toyota Camry
I have a 1995 camery station wagon manual the
I have had this same problem with my buicks, Try to loosen the bolt and push the wiper down and retighten the bolt (or nut depending on model) IF this does not help then yes the action arm that is hooked to the motor is worn
Apr 01, 2010 | 1995 Toyota Camry
Heater blower on toyota camry 1995 station wagon
Without knowing what is wrong. Have the guy pay to fix it. that way, no matter what it costs, its not your problem. $3000 is way to much for that old car, find something better.
Mar 13, 2010 | 1995 Toyota Camry
Theft deterrent system
Get the alarm removed.
Sep 24, 2009 | 1995 Toyota Camry
Cant find Toyota Camry 1989 Station Wagon fuse box
usually fuse box is located under the dash board on the driver side.
Apr 18, 2009 | 1989 Toyota Camry
DEI Python 1400XP Remote Start/Keyless Entry System Logo
237 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
