Where is the air flow meter on a 2.4 engine nissan truck?
  • 460 Answers
To better assist you I need more information about your vehicle I need the year
please
Posted on Aug 03, 2009
P1273 Manufacture contr fuel air metering 2004 nissan sentera
P1273 Nissan P1273 Nissan - Air Fuel Ratio Sensor 1 Lean Shift Monitoring Bank 1 Possible causes
- Faulty Air fuel ratio (A/F) sensor 1 Bank 1
- Faulty Air fuel ratio (A/F) sensor 1 heater Bank 1
- Fuel pressure
- Faulty Fuel injector
- Intake air leaks
- Faulty Air Flow Meter
Most probable is you have a bad heater in your upper bank 1 O2 sensor. Replace all of your O2 sensors.
Read more: http://engine-codes.com/p1273_nissan.html#ixzz3lgP7CTD8
Read more: http://engine-codes.com/p1273_nissan.html#ixzz3lgOwiMU8
Aug 27, 2015 | 2004 Nissan Sentra 1.8
Where is air flow meter located
The air mass sensor is located on the left hand side of the engine compartment. Follow the large hose which starts out as plastic down and to the front of the car. you will reach a rubber hose about 4" in diameter. It is attached to the back of the air mass sensor.
They stopped using air flow meters in 1979 (I beleive) Then they switched to what they call a "hot wire air mass sensor".
Apr 02, 2014 | 1986 Nissan Maxima
Air flow meter or air mass meter
The mass air flow meter is located at the air box where the air filter is housed.
I have nissan sentra b15 2001 the car starts but do not exlarate , the scaner detect the air flow sensser is bad , i got new one but now the car cranck but wont start yes i have spark
did you replace it with new one, or used one?? also have you replaced your air filter and used NISSAN only air filter. something tells me that you had non nissan/aftermarket air filter installed and that is why your air flow meter failed. you need to use nissan air filter ONLY in your model nissan. sentras do not like non nissan air filter, because non nissan filters are not coated in small amount of oil and let foreign particals / dirt go pass the filter and that will fry your $500 air flow meter.
Sep 16, 2011 | 2002 Nissan Sentra
The location of the air flow meter as you asked:- It is bolted on the side of the throttle bod.
Cheers.
Aug 01, 2009 | 1996 Nissan Pickup
My 95 nissan maxima hesitates on acceleration and stalls out sometimes
could be the air flow meter,,,they give trouble on most nissans,,,hesitating like you say and stalling can be caused by a malfuntioning air flow meter...
May 08, 2009 | 1999 Nissan Maxima
Where or what is a detoneation circuit
The detonation sensor is usually located on the side of the engine block - it is a cylindrical sensor that screws into the side of the block (and has one electrical conection) that picks up engine detonation and relays that back to the ECM to ****** the ignition timing when "spark knock" occurs. I'd bet the Air Flow meter is the culprit however, det sensor rarely go bad....
Jan 31, 2009 | 1993 Nissan Pathfinder
Poor idle, power loss off idle then takes off if you give it more throttle like a quarter more pedal, engine code says bank 2 is to lean
You need a new MAF (mass air flow sensor or air flow meter as its called). and you will also need a new air filter, since you most likely used aftermarket one and that's what killed that MAF sensor/meter. Aftermarket air filters dont sit right in the box and are not oil soaked, which helps to catch any debris and dirt coming into your engine. Replace you air filter with Nissan filter and install a new MAF/air flow meter. If your air box is dirty, clean that out too. MAF sensor will run you about $500 and the air filter about $17. Common problem on a Sentra if you are not using Nissan air filter.
Aug 02, 2008 | 2002 Nissan Sentra
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
