Question about Boating
My Boat Chokes down when put in gear. Not getting enough fuel
I have an 1975 850 Mercury. It idles fine, but when I put it in gear it bogs down... I need to clean the carb, how do I get to it?
  • 86 Answers
Lol...I have a 1965 650 and have done the carbs on it. You need to loosen the bracket in the front and get it out of the way the best you can. Use a 90 degree open end 7/16" wrench. On mine I think that I had to take the starter out also. Then once I could loosen the nuts on the carbs I had to twist, turn, and cuss alot until they came out. it is not a difficult job...just very frusterating.
Posted on Aug 06, 2009
1997 nissan bogs down at 200 rpm check engine light is on but dont know the code The truck will sit and idle all day but once put in gear and driven will bog down at 2000 rpm in all gears Was told it was...
Check the fuel pump output. Some will work but not have enough output for the instances you describe. Find a place that can test the fuel pump pressure.
Mar 24, 2014 | 1997 Nissan Pickup
My friend owns a 1995 Mercury Mystique.She had a new starter put in and after that the car will start but you cannot rev up the engine to drive it. If you rev it up very slowly the engine will rev,but if...
replace the fuel filter, first, if there is no check engine light, if that does not fix the problem ck the fuel pressure for possible fuel pump failure
Sep 01, 2013 | 1999 Mercury Mystique
Truck wont idle without carb cleaner
sounds like its not getting enough fuel change the fuel filter
Sep 29, 2012 | OEM 1988 Chevy K2500 Pickup Radio / CD...
40hp mariner sluggish
compressions more than 100psi ? carb clean and fuel not older than 5mths ? timing correct ? running on all cylinders ?
Mar 06, 2012 | Light Outboard Motor Boat Bass Fishing...
32LC trimmer will start and idle but bogs when trying to advance throttle. I can not get it to rev up. I put fresh fuel mixture in it, changed the spark plug, cleaned air filter, even purchased a new...
Did you try cleaning the carburetor before installing it? It may have factory oils and greases that are obstructing fuel flow.
If it runs fine at idle but bogs down when reving, then you are either not getting enough air or not getting enough fuel.
Have you notices any black smoke from the exhaust when you try to rev it? If so then you are running too rich and aren't getting enough air. You may want to check the path of air travel for other restrictions.
Jun 07, 2011 | Husqvarna Garden
Craftsman 42 in. deck lawn tractor. Will start and idle fine but when you let out on the clutch the motor bogs down and dies
few reasons will try to narrow down first start it and put in neutral and deck disengaged release clutch if bogs then fuel problem the carb may need adjustment or repair or fuel filter needs replacement----if no bog step on clutch no put in gear release clutch if bogs check drive belt -upper belt on engine pulley and check for binding an idler pulley problem -debris -or rear unit binding -needs service-drive pulley damaged-rear locked--if not bogging in gear step on clutch engage deck release clutch if bogs need to check deck -belts-pulleys -mandrels -bearings and for bent or binding blades good luck
Mar 10, 2010 | Craftsman Garden
2005 Mercury 50hp 2-stroke outboard motor very sluggish when accelerating, stalled twice when trying to exceed 50% throttle capacity. Last time I used my boat was about two months ago, so I don't think bad...
The carberator is gravity fed and there is propbably gunk in it, when you give it more throttle, it needs more gas but can't get it. Then a build up of gas in the float bowl occurs and nothing works right. It has happened to me and its aggravating, do a complete rebuild on the carb or just replace it and you will be happier quicker.
Hope this helps, Coachtheune
Oct 26, 2009 | Sport & Outdoor - Others
My mercury 35 hp outboard motor idle's fine but won't run
While at the river try to adjust the fuel air mixture. When you are on the water it puts the engine under a load and if that dont work then dont be afraid to bump up the idle stop screw slightly.
Aug 02, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
236 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
