Question about FrancisFrancis! X1 Espresso Machine
Not enough steam
The thermostat turns off too early, so that there is not enough steam or pressure to use for foaming the milk.
Please advise.
  • 3 Answers
Hello 828698,
One thing that you will want to look for on your machine is to be sure that your temperature gauge is not malfunctioning. In some cases with the FF machines, the temp gauge will not work properly but the machine is still working just fine. When you start up the machine you should notice the the bottom light on the left hand side will come on and be lit solid. Once the machine is up to brew temperature the light will go off or begin to flash. This means you are ready for brew. Then hit the steam button to prepare the machine for steam. Again, the light will come on and be solid until the machine is up to steam temp. Then the light will go off or begin to flash. If this is happening than your machine is working fine and only needs to have the temp gauge replaced. If, however, you do not see this light go off it could be a couple of things. The control board could be malfunctioning, or the heating element is no longer maintaining the proper temperature. In this case it is generally recommended that the machine goes in for service. Or, you can contact Empire Fulfillment (877-855-4540) to order parts for the machine if you are comfortable doing the repair on your own.
Posted on Aug 05, 2009
Delonghi EC702
Even semi skimmed milk with froth if hot enough. Check the steam temperature, you may need to blow steam through the milk for longer.
Mar 06, 2014 | Coffee Makers & Espresso Machines
Hi, I bought my kitchenaid artisan coffee machine on ebay. I can't get the steaming of the milk right. It froths too much so can't make just a latte or flat white. It looks to me that the nozzle...
there is an art to working a foamer ... hence the "artisan" in the coffee-maker's name. There are several aspects to a good foam:
1. If you have been using regular milk to make your foam, try half-and-half ... the thicker consistency will give you a different result.
2. If you have been jamming the foamer head all the way to the bottom of the milk while you are foaming it, try submerging less of the foamer ... this will cause the steam to have a slightly different effect on the milk. If you have been submerging it only about half way (or not at all) try different depths. If one consistent depth is not right, try swirling it around while you foam the milk.
3. Try a different amount of steam (if your steam release valve is adjustable). Pushing a lot of pressure into the milk will give you a different result than barely turning it on.
4. Are you using a cold container or a warm one to hold the milk you are steaming? If you are still not getting the results you are looking for by playing with the other aspects of your foaming process ... try a different container (it sounds silly, but it can really help).
Before you go out and spend a bunch of money on different replacement parts for your machine, spend a while playing with these aspects of your foaming process. If none of these ideas help, then you should consider replacing pieces. Foaming milk is not as easy as it sounds ... it took me a few months of (once daily) use to really get my technique down so I could make a reliably decent foam. Don't give up! and good luck!
Jun 01, 2011 | KitchenAid Artisan
I have the via veneto model that has the rubber tube that draws the milk in. It doesn't seem to build enough pressure now to do it. I have been cleaning and descaling it on a regular basis. The expresso...
Hi
There is a pin on top of the cappuccinator the will twist to create suction. Turn it slowly when steaming until it starts to draw milk up to foam. Then leave it. If you don't have the pin, thats your problem.
Jan 02, 2011 | Saeco VIA Veneto Espresso & Coffee Maker
Not enough steam is produced to make good froth.
I have one too and what I do is: turn all 3 switches on and while I'm waiting for the "ready" light to come on I go ahead and pour the milk into my frothing pitcher and prep my espresso basket.
After the "ready" light comes on I install my espresso basket and turn the handle to the "left" so no liquid starts coming out.
Next, I take an empty coffee cup and hold it under the steam nozzle and start opening the steam valve until I get only steam instead of a stream of hot water. Once you have steam, close the valve, put your pitcher of milk under the steamer and froth as usual to around 150 degrees.
Jan 21, 2010 | Coffee Makers & Espresso Machines
Turn the foam knob, nothing happens most of the time. If I leave it open, it will pizzle and fizzle warm, low pressure air that takes 7 minutes to warm milk to 160 degrees. Bah! I miss my lattes!!!
Hi
That sounds like your Steam thermostat needs to be replaced. There are 4 thermostats on the SL70. The rear one is your brew thermostat (92c), the one in the front is your steam thermostat (117c). The one in the center is over temp thermostat, (136c) and it screws in to hold the other thermostats in place with a thermal fuse held also. You need the 117c thermostat and maybe the 136c also. You will also need an new O-ring for the steam wand.
Oct 18, 2009 | Solis Crema SL-70 Espresso Machine
Bialetti mukka express
First off, the best milk for foam is skim milk (0% fat). The higher the fat content, the less foamy your foam will be.
The foam is created by the steam/hot coffee from the lower part being forced through the doohickey and into the milk. That means that if the coffee itself isn't "perfect", the foam won't be "perfect". I've found that using different types of coffee (e.g. different grinds) or filling the coffee bin to different levels results in more or less steam/pressure being passed through, so the foam is better/worse. For example, if I put too much ground coffee in the bin or use too fine a grind, it blocks the water/steam that's going through the coffee, resulting in less coffee and weaker coffee, and also resulting in less foam.
Apr 12, 2009 | Bialetti Mukka Express
Milk temperature setting
Hot Milk:
steam pressure time 6
puls width 1
puls period 15
Milk Foam:
puls width 1
puls period 15
Hope this will help you.
/Mirran
Aug 28, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
New Rancilio Silva - steamed milk not perfect
please relay on your experience realizing that you now have new steam pipe(with different holes in the end of it and different pressure)
you will need to get use to them and get maximum quality of that steam pipe.
my advice:
  1. every time hold your hand in the bottom of milk container, so that you will prevent overheating which often gives the result you mentioned.
  2. every time you use cold milk.
Jul 22, 2008 | Rancilio Silvia Espresso Machine
Philips HD-5661 How does Foam maker work?
I recently acquired the same model of espresso maker. I have found that you have to turn it on, and give the water time to heat up before attempting to use the steam function. If you turn on the steam knob too early, it will shoot out a stream of water, so you have to wait till the water is hot enough... probably 3 minutes or so. I'm assuming that you already know that you just place the steam spout into a mug of milk to both heat it up and create foam simultaneously. -Tim
Sep 23, 2007 | Philips HD-5661
FrancisFrancis! X1 Espresso Machine Logo
285 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
