Question about Nikon Coolpix 8700 Digital Camera
Camera turns on but does not work
When I turn on camera the lens zooms all the way out and won't take a picture. Camera has a mind of it's own. Please help.
Re: camera turns on but does not work
Posted on Dec 22, 2007
0 characters
3 Points
My canon rebel xsi won't take a picture with the .18-55m lens zoomed in
Clean the contacts on the lens? Your lens maybe defective need service?
Apr 08, 2012 | Canon EOS Rebel XSi Digital Camera
Fujifilm finepix j38 series reads zoom error and wont take a pic.
If you have some skills, you can open the camera and cline your zoom lens with toothbrush and compressed air. Try to separate zoom lens from the electric motor. usually is 2 or 3 screws. You will see a lot of sand inside the camera and lens. And next time when you will go to the beach, you will take more care about your camera.
Solution 2, and more easy is to buy another zoom lens from ebay.Or another camera same model with broken LCD or other technical problem than zoom lens.
May 31, 2010 | Fuji Digital Cameras
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Sony dsc t300 e 61:10
   The detail of fault is given below,
Self-diagnosis Code   Symptom/State
E 61:10         Zoom operations fault
               (Cannot initialize zoom lens.)
Correction :
Retry turn the power on by the power switch. Check the zoom
reset sensor of lens block (pin 9 of CN402 on the SY-191
board), if zooming is performed when the zoom button is
operated. If it is OK, check the zoom motor drive IC (IC401 on
the SY-191 board).
According to the symptom the possible fault is described above, You have to contact any nearest SONY SERVICE CENTRE to rectify the problem.
May 30, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
Can't take picture
Needs to go back to Panasonic- an inherent fault.
Aug 16, 2007 | Panasonic Lumix DMC-LZ7 Digital Camera
Blurry pictures, and zoom not working
yeah the same thing happened to my camera last month and I just went to the repair place yesterday. Apprently Casio products arent that sturdy so if they get hit the lens can become misalligned and you can't fix it yourself. A new lens is more than the camera itself so if you have to get a new camera I wouldnt suggest another casio one. Good luck.
Aug 13, 2007 | Casio Exilim EX-S600 Digital Camera
Detaching the lens
Perhaps a Vacuum will help if it is sand in the mechanism then has to be sucked out - not blasted further in. But I fear it may now be terminal. Preparing these item is not an economic proposition
Jul 02, 2007 | Kodak EasyShare DX6490 Digital Camera
Nikon Coolpix 8700 Digital Camera Logo
94 people viewed this question
Top Nikon Digital Cameras Experts
Are you a Nikon Digital Camera Expert? Answer questions, earn points and help others
