Question about Brother IntelliFax-2820 Laser Fax
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
  • 105 Answers
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Posted on Aug 03, 2009
Drum Life Ends soon - Brother
The problem with this is the design. Each toner cartridge has a microchip on it, that counts the pages you print. The company has determined that you get x amounts of prints. Then you have to replace it, empty or not. This printers do not work the same way as an expensive professional business copier. In an pro style there is a spent toner cartridge that collects all of the wasted toner that is on the drum. On a small business/home style this spent toner goes back into the cartridge. There is no level indicator, even on the inkjet printer. They too, have a chip that says you have x amount of prints/cleaning cycles they can go through. Look up inkjet refill kits or inkjet cartridge programmer.
Mar 31, 2014 | Brother Mfc-7340 All-in-one Laser Printer...
Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
hi
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Oct 07, 2008 | Brother Office Equipment & Supplies
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Light print on side of paper. color black copies, print, internal
Ninty-five percent of all image issues like this are caused by the carona-drum-toner assembly. I have not worked on this model but the only way to diagnose the issue is to try a new drum / toner cartridge and see what impact it has. Then once you resolve the issue you can discuss the service life after the fact.
May 12, 2010 | Brother MFC-9440CN Laser Printer
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
May 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Print Quality Problem with Brother 2820 Fax
sounds like you are using generic drum and toner. try OEM (brother brand). you say copies are coming out completely gray. try printing an internal report from the control panel. if that is gray or received faxes are gray, then the problem is not in your scanner area, and i would wager you are using "generic" supplies.
hth,
razors
Apr 10, 2009 | Brother IntelliFax-2820 Laser Fax
Brother MFC 8860DN Toner End Life Error
Open the door where the toner goes. Press the 'back' button. Press *00. Do not respond to the query about the drum. Close the door. Other models may have to press the 'Options' button located near 'Copy'. This should work.
Jul 08, 2008 | Office Equipment & Supplies
Change of toner
I have a brother mfc 7840w
I first used the electrical tape trick and that worked for a while. Then got the toner low message again. I then tried the *00 trick, which works as follows:
1. lift lid and open front cover
2. press clear/back. "Replace Drum?" will appear on the screen.
3. Press "*00" it will then read accepted and the toner low error (End of Toner Life) should go away.
4. close it all up and your done.
Jun 08, 2008 | Brother MFC 7420 All-In-One Laser Printer
Black pages when making a copy or printing something
Have you tried both drum and toner supplies? cause it sounds like a drum fault, if you have tried a new drum and toner, and it is doing it when printing internal reports, receiving fax's and copying then you have a tecnical issue to do with charge and this would likely render machine unecomical to repair (unless you can find a bad contact with drum on machine). If it receives faxs clearly but copys black then it is different issue (ie optics).
Oct 16, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
1,137 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
