Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Trying to replace the head of the weeder with a new line system,
I cannot get the head of the weed eater off, i am trying to put a new line feeder system on it. How do i get the head off.
I cannot get the head of my craftsman 791050 head off to replace with a new line system
Posted on Aug 01, 2009
John deere 260g weed eater how the line goes on keeps breaking
Does the line break or is it the head. If it is the line try using a thicker type of line, or a better brand. if the head is broken this may need to be replaced, but first check to see if you have it correctly assembled.
Aug 10, 2011 | Garden
How do I remove the spoolhead so as to afix the pivotrim head
I installed the Pivo trim head yesterday. The info that came with the unit will show you how to install it on ANY Weed Eater Unit. Also they have videos on their web site at: https://pivotrim.com/
Look on the end of the shaft of your weed eater at the head. Mine was a 25cc Poulan/weed eater SST45 and it has a hole that you need to stick a HEX KEY in so the shaft does not move when you try to remove it. ALSO it has a BACKWARDS THREAD!!! So "Right is NOT Tight." Left is to tighten and turn towards the right to get the head to unscrew so you can put on the Pivotrim Head. Also you can use ANY Weed Eater line on the unit. As I tried several different lines and found different uses for different lines. Such as edging and trimming against fences. Best after Market Weed Eater head I have EVER used. :-)
Enjoy! :-D
Jul 28, 2011 | Craftsman 25cc Gas Line Trimmer
I am having trouble taking the old speed feeder head off the weed eater to replace it with a new one.
If you are trying to loosen the nut, the nuts are threaded to stay tight when running and may well be LEFT hand threaded, so you will need to turn to the right to loosen.
Jul 09, 2011 | Garden
Weed eater works fine but the Auto Feed System is not releasing any string when it becomes too short to cut grass like it used to. Do I need to buy a simple replacement part or is there more? Thanks
Look inside the trimmer head for grass debris which is jamming the line feeder operation. It may need to be scraped out if the material is really solid. Also, look for plastic parts that have worn and formed 'lips' where none should exist. Hope this helps!
Aug 16, 2010 | Garden
Want to remove huscavana weed eater head
You should find a hole in the piece just above the trimmer head, this should line up with another hole deeper in the area. You stick a piece of rod in there to keep the head from turning. Use some pb blaster penetrating oil to help loosen up the head.
Feb 25, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
I can not remove the top off the weed eater to
They usually have a hex-head bolt cast inside the plastic knob, the head starts spinning inside. You might be able to loosen the knob by gripping it with Vice-Grips really tight, then get a new knob. Should be right-hand thread.
Apr 26, 2009 | Garden
Screw cap to reel head of ryobi ss30 weed eater will not come off
The spool retainer nut loosens when you turn it clockwise . The opposite of " normal ".
Apr 05, 2009 | Garden
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
1,413 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
