Question about Seagate 80GB Barracuda 7200.9 SATA s - 8MB Cache (5-pack) 80 GB IDE Hard Drive
Need to replace seagate 7200.10 320gb S-ATA hard drive - Help pse
I have Seagate Barracuda type ST3320820AS S-ATAII 3.5" 7200rpm
8MB cache. 18 months old but system does not recognise it now, so must be faulty. Pse advise what I should replace it with (Apparantly lots of people have trouble with this type). 320GB hard disk size.
It can be bigger hard drive capacity as long as it will be okay for my computer. Please advise.
Thanks
  • 66 Answers
Do not do it
Posted on Aug 01, 2009
Hi I have a Seagate Barracuda ST2000DM001 2TB 7200 RPM 64MB Cache.It runs fine for a bit then it just diconnect itself,so you have to scan for hardware or you have to reboot the system.Is there a fix for...
Test your HDD (Hard Disk Drive): go HERE, click Downloads and download Seagate Seatools for DOS (free). Burn the ISO to a CD, set your 1st boot device = CD drive and reboot with the disk in the drive. When the tester loads, choose the Quick Test in the upper left corner of the screen. It takes 5-10 minutes and will give you a pass or fail. If it tells your that SMART has tripped, or gives a fail notice, your drive is failing. You should have a warranty on that drive with Seagate.
If the drive passes as good, change your data cable. I have seen bad cables cause problems. Also check the power cable.
If you still have problems, enter Administrative Tools\Disk Management. Find your drive, Right click on it, and click "Mark Partition as Active".
If still no joy, try changing the SATA port on the mother board that your drive is plugged in to.
If still no joy, contact Seagate customer help, they are very good.
Oct 08, 2013 | Seagate Barracuda 7200.10 / 500GB / 7200 /...
What kind of hard drive enclosure would i need for a Barracuda ATA IV model ST380021A?
im not sure what you mean this hard drive should fit into a computer without a need for any extra enclosures just the normal leads if you want any further assistance
http://www.seagate.com/cda/products/discsales/marketing/detail/0,1121,381,00.html
hope this helps
Apr 19, 2011 | Seagate Barracuda ATA IV (ST380021A) 80 GB...
Which is the correct jumper settings on Seagate Barracuda ATA IV 80 GB Hard Drive
Hello Please see the image below for correct jumper setting cmptrlink_16.jpg
Hope this helps, if so do rate the solution
Jan 15, 2011 | Seagate Barracuda ATA IV (ST380021A) 80 GB...
I require a driver for a seagate barracuda 7200.7 160GB hard drive
Seagate and Maxtor-brand External Hard Drives
External drives contain a standard computer hard drive in an enclosure that makes it possible to connect it to in of your computers external data ports (USB, FireWire or eSATA). This makes it easy to add a drive for backup or data storage to any computer with a compatible external data port.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">external hard drives
do not require additional drivers to function in Windows Vista
Microsoft Vista is the successor to Windows XP operating system. ', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Windows Vista
, Windows XP
Microsoft Windows XP is the successor to Windows 2000. ', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Windows XP
, Windows 2000
Microsoft Windows 2000 is the successor to Windows Me.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Windows 2000
, or Mac OS X
Mac OS X is the operating system that is produced by and comes standard on Apple computers.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Mac OS X
. These external drives are supported by the standard device drivers that are already included in these operating systems out of the box. Installing Serial ATA drives requires the installation of drivers from the Serial ATA motherboard. Click here for more information on this subject.
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=201413&NewLang=en
Oct 25, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I have a seagate external hard drive that I dropped, and now the blue light stays on, but the computer does not recognize it. is there a way to retrieve the info?
Are you using XP?
It should show up. Are yo sure you are plugged in correctly everywhere?
Check your device manager ...
Let me know if this works for you.
a
Sep 26, 2009 | Seagate USB 2.0 External Enclosure + 300GB...
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
Windows
I've just installed the same type of hard drive in my PC running win XP and have no problems.. do u know that you need to format the disk before it will show up with the other accessible drives?
what to do is - click start, right click on my computer and go to manage.. then double click on storage, disk management local.. and it should show up here, once you format it your all set..
No need for drivers, windows has them already, it's all generic one's the windows is familiar with..
Hope this helps!
Dec 16, 2007 | Seagate Barracuda 7200.9 ST3400833AS 400GB...
Harddrive
Hi, Looks like it will be a motherboard issue not Maxtor (ATA) and Barracuda (SATA) combination. So the question really would be if your motherboard would accept and recognize the Barracuda SATA. Post back with your motherboard details, (brand/model/version). Kind regards.
Aug 30, 2007 | Seagate Barracuda 7200.8 300 GB Hard Drive
Seagate 80GB Barracuda 7200.9 SATA s - 8MB Cache (5-pack) 80 GB IDE Hard Drive Logo
214 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
