Question about Amana PTH123B25AJ Heat Pump Air Conditioner
My Amana heat pump model PHD60C02F1 Keeps tripping the circuit breaker
  • 614 Answers
Is this kicking the ground fault on the cord or the breaker. If it trips breaker could be bad breaker. If it trips quickly it is a short in the unit. Russ
Posted on Aug 01, 2009
Amana RCE24C2A trips circuit breaker
tripping the circuit means the unit is has a ground, "means some peeled wire inside is touching its metal case"
Jun 01, 2013 | Amana Heating & Cooling
Model 4001-ov trips the circuit breaker.
Assuming you have Paragon 4001 40 amp 120Volt timer
By-pass the timer so only pool pump is connected to breaker.
To do this, move wire from terminal 2 and connect to terminal 1.
If breaker no longer trips, then replace timer with Intermatic T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Crossover wiring: Paragon terminal 1 goes to Intermatic terminal 1.
Paragon terminal 2 to Intermatic terminal 2.
Paragon terminal 3 to Intermatic terminal A
If breaker keeps tripping after bypassing timer, then tighten wires on circuit breaker and test again.
If breaker keeps tripping, then move wires to another same-size breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Breakers trip when they sense overheating.
If motor is causing problem, you might need electrician to track down source of overheating.
Jun 19, 2012 | Paragon 4001-0G Defrost Timer
My amana Ptac keeps tripping breaker.
Must be a swolen or shorted capacitor, that would be the first thing I would checkthemobilian_3036.jpg
Sep 30, 2011 | Amana PTH123B25AJ Heat Pump Air...
I have a Amana PTAC model PTC123A50AC never had any problems until this a.m. walked into office were installed no heat. Breaker tripped, reset breaker, nothing. Checked outlet, getting power. Any idea's?
To all friends! Whenever you find breaker tripped or fuse blown, it's an indication some device/s are in problem.
To get tripped breaker:
1. Condenser too dusty- clean it.2. Fan motor or compressor grounded-Replace. 3. Compressor high amps due to capacitor weak-replace capacitor. 4. Burnt wire-rectify. 5.Short circuit-rectify.
Jan 11, 2011 | Amana Heating & Cooling
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
Trips circuit breaker
If the unit is new then the unit may be over-sized for the electrical circuit. If the unit is not new then the compressor may be failing
Apr 19, 2010 | Amana PTH153B35AJ Air Conditioner
I have an Amana PBE12 Thru-Wall AC/Heater for my Florida Room. The unit will run for a short time before it trips the circuit breaker. Any ideas?
is the breaker large enough for the unit? this could be the compressor locking up if if it a heat pump style, or sticking thermostat..
Jan 17, 2010 | Amana PBE12 Wall/Window Air Conditioner
My microwave oven keeps tripping the circuit breaker.i replaced the outlet that it plugs into but it still trips it. is there an internal fuse in the oven that may be bad?
If a fuse inside had blown, that would definitely reduce the current flow rather than trip the breaker.
I have replaced several breakers over the years; they no longer last forever.
Try your Amana on a different circuit, not in the kitchen; if that other circuit likes the oven, the breaker is bad. If the alternate circuit breaker also trips, then you have not a blown fuse in the Amana but rather a shorted component inside and repairing the oven will likely cost about the same as replacing it.
Nov 22, 2009 | Amana Radarange Microwave Oven
Amana Heat Pump Tripping Breaker
My guess I would say, you either have a wire that is short to ground or if the contacter pulls in, then I would say the compresser is short to ground.There also could be some capacitors that could be short.
Apr 07, 2009 | Amana PTH123B25AJ Heat Pump Air...
Heat pump trips circuit breaker
I seem to have the same problem. But when I reset the breakers, they won't stay in the on position. They go back to the off position. What gives? It is 95F inside the house.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
627 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
