Question about Canon PC-940 Black and White Copier
PC-940 Cartridge stuck
Started printing the whole page black. I tried to take cartridge out and it seems stuck and won't come out. Scared to pull on it too hard.
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,346 Answers
Re: PC-940 Cartridge stuck
Turn off machine, you can move the cartridge head back and forth when it is off. If it won't move there is something that is loose and is in the way, check.
Not sure if you mean it is stuck when it was moving or if the cartridge is stuck in the printer?
Posted on Nov 29, 2007
0 characters
3 Points
How to turn off test print on a HP DJ 6122.
Yes.Tell it to print a dot short word and when it starts printing unplug the power cord so it stops with the printhead somewhere to the left. Then do your cart change. It won' t know you did anything.
The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Feb 06, 2014 | HP Deskjet 5940 Photo InkJet Printer
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Printers & Copiers
Black ink is coming out on one side of paper only
If this means that part of your page is coming out blank then the easy fix for this is to remove the toner cartridge and while holding it level, shake the cartridge from side to side. This will re-distribute the toner inside of the cartridge and restore printing to the reset of the page. Just re-install and test. This happens most often when the cartridge is starting to get low on toner so you may want to begin the process of getting another cartridge on the way.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 02, 2011 | Canon PC-940 Black and White Copier
Our pc 940 does solid black copy
There is an open circuit on one of the charging components in the printer cartridge, the Canon E40. Replacing the cartridge should solve the issue. Be sure to use a high quality remanufactured cartridge or an original to try to avoid such issues.
Jan 18, 2010 | Canon PC-940 Black and White Copier
Dell 1720 lazer printer only printing solid black pages
The corona wire is not charging the drum properly. Try pulling the toner cartridge out and then re-seating it. If this doesn't work, try a new toner cartridge as the corona wire is usually included in the cartridge.
If you are using a refill toner, there's an outside chance that the supplier put toner with the wrong electric charge in the cartridge. Again, changing the cartridge should fix this(assuming the replacement is from another batch).
Jul 25, 2009 | Dell 1720dn Laser Printer
Canon Multipass F30 not printing
Did you remove the tab that covers the cartridge head where the ink comes out, if the drivers and software that you loaded on your pc work
good and your printer shows under device MGR, then it is the printer
itself,,most times you can not see how much ink in the cart,,,most are sealed,,,just try to put the cart in again and make sure it is locked in good,,try running the cleaning program with pc,,make sure the right
cart is in the right spot, bl in one spot and color in a spot.
Dec 30, 2008 | Canon MultiPASS F50 All-In-One InkJet...
The ink cartridge in my Canon - PCII is stuck.
put off your copier. kindly look at the side where your paper exit , u see an opener, this will open the copier. then draw the cartridge
Dec 05, 2008 | Canon PC-940 Black and White Copier
HP 7830 printer: changed black ink cartridge, prints windows test page then errors, cartridge gets stuck halfway across during printing.
Thanks for posting in FixYa.
It seems that the Cartridge is now correctly fitted in the printer. Please remove the catridge during Power off and then install it firmly. Reboot the Pc and power on the Printer. Hope it will fix the issue.
Let me know if you need further assistance.
Sep 20, 2008 | Printers & Copiers
New cartridge
Yes, it should.. It releases the toner into the developing unit. You may want to try running some blank page through the copier to get the toner moving evenly in the developing unit... Or it could just be a Bad cartridge. If you put the old one back does it work???
Sep 10, 2008 | Canon PC-940 Black and White Copier
Canon PC-940 Black and White Copier Logo
162 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
