Question about Brother PE-150V Computerized Sewing Machine
Check if the tread is entagled or needle is bent...
I have a brother sewing machine PE-150 but when I started sewing an error message appears "check if the thread is entangled or needle is bent".. I tried changing the needle, re-threading and cleaning the machine but the error still appears... please help....
I think you will find the motor is not working
Posted on Sep 30, 2010
The tread is breaking while sewing with brother ls 2125
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Nov 12, 2012 | Brother LS-2125 Mechanical Sewing Machine
Needle keeps breaking HELP!
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
I suggest contact brother.com or a dealer about the needles , cause
I've checked on the internet and on the brother site about the needles and couldn't find any information.
Jul 26, 2012 | Brother PE-150V Computerized Sewing...
I am haveing trouble with the top thread not sewing, the bottum tread come to the top; I have ajusted the theard tinshen , nothing works. glenda@netzero.com
you might check your needle to see if it's bent-roll on a flat surface to see if it roll correctly
if the needle makes a popping sound going into the fabric then the needle is blunt
check to see if the top thread is catching on the spool pin or the spool of thread it's self, where the little notch is at the holds the thread
I've had the thread to come off the thread take up lever several times
let me know if this helps you
Sep 23, 2010 | Brother PE-150V Computerized Sewing...
What size needle for my brother pe-150
The size of the needle depends on the type of fabric you are sewing.
Sep 10, 2010 | Brother PE-150V Computerized Sewing...
I have a brother pe- 150 and the bobbin doesnt catch
See if you may have thread wound up inside the bobbin hole. The hook needs to cross the needle hole when the needle bar starts up. Adjust needle bar to make up for it.
Dec 31, 2008 | Brother SE-270D Computerized Sewing...
My Brother PE 150 will not pick up bobbin thread. I changed needles cleaned it etc. nothing helps.
My pe-150 embrodery machine is not grabing the tread right since I changed the needle out it keeps promping me to check my threading
Sep 07, 2008 | Brother PE-150V Computerized Sewing...
Problems
I had the same problem, but I then got a shorter bobbin. what is happening is that the bobbin is too tall and the tread is getting stuck in the bobbin. It helped me from trashing my machine.
Aug 25, 2008 | Brother PE-150V Computerized Sewing...
Problem with my machine
l have a pe-200 brother machine and the needle won't go down and is making a noise can anyone help .l have checked belt and that's fine thanks
Dec 11, 2007 | Brother SE-270D Computerized Sewing...
Brother PE-150V Computerized Sewing Machine Logo
187 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
