Question about Bose Lifestyle 48 System
My bose was playing stored music and then for no reason it has stopped. can play cds ok
My bose stereo system plays a cd for a few minutes then stops, what is this, and it says failed code, call Bose. How do I fix this.
Posted on Aug 23, 2009
Won't read, play, or store music.
Performing a product reset To reset your system, follow these steps:
  1. Turn your system off. Wait until "Saving your music information" disappears from the display
  2. Unplug the Acoustimass® module power cord from the power outlet
  3. Wait 60 seconds
  4. Plug the Acoustimass module power cord into a working power outlet
  5. Turn the system on
Note: After the reset, wait several minutes before playing stored music (stored music may not be immediately available depending on how many CDs have been stored). All other sources are available, immediately after the system is turned on.
Feb 06, 2016 | Bose 3 2 1 GSX System
Why won't bose play some cds
Could it be the CDs you can't play, are burned in a PC?
Not all CD players can or will play CD's burned in a PC. Sometimes the CD player is to old, so not compatible with these CDs. Sometimes the player just does not play these CD's, because of rights protection.
A CD burned in a PC is less reflective than an normal music CD. Normal CD's do have a metal coating and are highly reflective. Burned CD's have a dye, and where the laser burned the dye, it only changed colour. Making it less reflective.
All modern CD playes should be capable of playing CD r's. But the player that is really compatible, is labelled CDr and CDrw compatible.
May 13, 2014 | Bose Wave music system Multi-CD Changer...
Not playable bose
your car stereo and computer are more than likely able to play the files but the bose cannot because the music files are burned in MP4 format I believe. I'm not sure if iTunes can be converted to MP3 so it will play in your bose.
Nov 09, 2013 | Audio Players & Recorders
Can't play burned cds through bose
get a 3.5mm male to 3.5mm male cable(one end to the laptop headphone jack and the other end to the AUX jack of the Bose wave music system), you are good to go...
Jan 01, 2010 | Bose Wave Music System CD Shelf System
Player will not play cd - it reads then says
Your CD player is failed. It will need to be replaced. Some folks can repair but it cost less to have it replaced. If no one local will do it BOSE will for about $150.
Jul 11, 2009 | Bose Acoustic Wave music system II -...
Bose lifestyle 48 says format unsupported for audio cds
Hi Johnxxlt,
According to Bose, the message that you have is due to dust in the system ....
They have offered 3 ways :-
Try cleaning the CD or DVD, as follows:
  • Use a soft, dry, lint-free cloth to remove stains or fingerprints from the disc surface
  • Wipe in straight movements from the center of the disc to the outside
  • Do not use any chemical cleaning products. They can damage the disc.
If the above will not fix the problem, you need to call them to repair the system.
I know its frustrating, However, we cannot play more with Bose as it might void the warranty if any.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Apr 17, 2009 | Bose Lifestyle 48 System
Everytime I want to play an audio cd, it says format unsupported. This is happening very often. And I have also cleaned the cds,but still there is no difference. What is the solution?
Apr 08, 2009 | Bose Lifestyle 48 System
Bose Lifestyle CD not eject
There are some repair instructions available at www.AnyoneCanFixIt.com in the electronics section that will show you how to release the CD magazine and fix the problem where the unit will not play the CDs (you will hear a buzzing, buzzing, buzzing, and nothing will load or play).
Oct 11, 2008 | Bose Lifestyle 20 Shelf System
Bose Wave Music Sys & 3 CD Changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will probably have to be disassembled to get the CD out or have it serviced.
Dec 23, 2007 | Bose Wave music system Multi-CD Changer...
Playing CDs
An old post but did you get an answer and do you need a copy of the manual?
donald
Jun 29, 2007 | Bose Wave music system Multi-CD Changer...
Bose Lifestyle 48 System Logo
232 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
