Question about Refrigerators
Heavy frost build up on back panel of freezer side of refrigerator and both sides are warming. Is the defrost heater bad?
  • 374 Answers
if your able to defrosting your freezer and it happen that melting at both side only,but it should not building up frost,your defrosting switch or your defrost heating element is busted.you cant check using multi tester perhaps you should knowledge on using tester.this should be done by ref/aircon technician.have a nice day.
Posted on Aug 01, 2009
Why does The freezer side stays cold but the refrigerator side gets warm
Your problem is more than likely a defrost issue. There is ice building up in the freezer coils and when it gets blocked with ice the cold air cant blow into the fresh food section. When you shut it off the ice melts and it gets cold again for a few days. remove the freezer back panel and check the defrost heater and defrost thermostat. if they check OK then check the defrost timer. It is best to replace all three components at the same time. This way you will be starting out with new components rather than one failing then the other.
Jul 16, 2014 | Kenmore Side by Side Refrigerator
Hss25gfpd freezer not freezing
when you had the back wall off how did the evaporator coil look?was the frost pattern even all over the coil or just on the top or bottom,if it didn't have an even frost pattern covering the whole coil you have a freon leak and will have to replace the machine.it will just keep getting warmer
Jul 08, 2012 | Hotpoint HSS25GFP Side by Side...
Freezer is cold but refrigerator side is barely cooling. turned off and water leaking out of door on the freezer side
Hello Roxanne,
what the problem most likely is a failed part of the defrost system Do you see a bunch of frost built up on the back wall of the freezer? If you do frost build up,i would take off the back wall of the freezer and replace the deforst heater and defrost termination. A hair dryer could be used to melt the built up frost from the coil behind the back wall. Another part that will cause frost build up is the defrost control, that isn't the freezer behind the back wall but instead in the fresh food compartment in the control panel where the thermostat is. I would replace heater/defrost termination first though since they are the most likely to fail parts.
I hope my answer will help you to fix your refrigerator,
Gene
Aug 05, 2011 | Maytag MZD2766GES Side by Side...
Defrost not working heavy ice build up around coils
Hi
Frost is a natural occurrence on the evaporator coils in the freezer compartment of your refrigerator. To prevent frost buildup, a self-defrosting refrigerator warms the coils using a defrost heater several times each day to melt away the frost. This frost melts into water and flows out of the compartment through the drain. If any part of the defrost system is not working properly, the result can be heavy frost buildup that may affect the cooling capacity of the refrigerator.
The defrost timer is a mechanism that tells the defroster how long to run to melt the frost. The limit switch measures the temperature in the freezer and helps to maintain it, while the heater is the key element that melts the frost. Any one of these components could need replacement at a given time, which will result in this over-frosting.
Also check this bellow link:-
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | Samsung RS2530BBP (25 cu ft) Side by Side...
Freezer developing frost while the fridge is warm
The frost build up is causing airflow blockage to fresh food compartment. Frost build up is either a sign of poor door seals, door left open, or bad defrost circuit. If after manually defrosting and after a few days the frost reappears, problem most likely is with the defrost circuit.
If you have some background of electrical circuits you may attempt repair yourself or call in a tech.
Defrost timer on your unit is near the light in the refrigerator. Recessed in a hole, turn with a flat blade screwdriver and advance timer until you hear a click and refrigerator turns off. After a few minutes the heater should come on and should hear moisture hitting heater in freezer compartment in back panel.
If heater is not coming on, could be a bad heater or defrost thermostat is bad. Both of the parts are accessed through the back panel inside of heater. Unplug and ohm check for continuity of heater & defrost thermostat. Heater is a cal rod unit, thermostat more likely to be the problem. part #5303918202
Jan 30, 2011 | Frigidaire FRT21P5A Top Freezer...
Fridge and Freezer Not getting Cold
Your defrost system is at fault.
With this brand it is most likely the defrost thermostat and defrost heater located behind the back freezer panel.
Remove the shelves and bin,then remove the freezer panel. Defrost the ice manually.
Replace the thermostat and heater assembly.
Apr 27, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The Freezer is working but the the refrigerator side is warm, What causes this?
Look for heavy frost on the back wall of the freezer panel, if there is frost the defrost heater has gone bad.
Apr 25, 2010 | GE GSH25JFR Side by Side Refrigerator
Runs constantly, freezer isn't cold enough, bottom of fridge is freezing
Do you have a heavy frost build up on the back wall of the freezer section toward the bottom. If you do your defrost heater has gone bad and will need to be changed. If you do not have frost build up the other problem would be with the evaporator fan or the main board. Let's hope for heavy frost build up.
Mar 09, 2010 | Hotpoint HSS25GFP Side by Side...
Freezer building up with frost
Sounds like the defrosting system has a faulty timer/board, faulty heating element or bad electrical connections to these components.
More info, let me know...
Charlie
Aug 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
