Question about Panasonic Televison & Video
Fault F04 VCR turned itself off during play. Then wouldn't eject cassette. Managed to retreive it, now wont accept cassette. Fault F04 has displayed once. Power is still on with clock display.
  • colin_angie Aug 01, 2009
    VCR is a Panasonic NV-SD200series
    Champion:
  • 221 Answers
F04 is "loading lock". most likely problem is that the timing of the gears in the tape loading mechanism is mis-timed.
Posted on Aug 05, 2009
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
Unit accepted cassette, won't eject
check the tips in my profile
May 10, 2010 | Sony EVC100 Hi8 VCR
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
Apr 08, 2010 | Sony EVC100 Hi8 VCR
Inserted cassette doesn't play and immediately ejects
Could be a mode switch problem, you could try Servisol video 40 on the switch, or it might need replacement.
Mar 03, 2010 | Panasonic PV-V4022 VHS VCR
Tape would not come out.
Not sure on the removal, but if you replace the mode switch the machine might come back to life.
Jul 31, 2009 | Panasonic PV-7400 VHS VCR
Will not display picture or eject tape.
most of no signal means dsr 11 or similar machines have dirty heads. When they get dirt sometimes, you can´t play a cassette and the machine turns off (with the cassette in).
I´ve tried several times to reload the cassette and I manage to make it work again.
with the cassette in and the machine off press at the same time power and fast forward.
When in fast forward press play and your head should be starting to be clean (takes 4 o 5 minutes
to get a clean picture). Normally the machine gives a code error like if it was a loading problem but
not nearly related
Mar 13, 2009 | Panasonic Televison & Video
Go-Video VCR Problem with accepting/ejecting tapes
As with any VCR, there are rubber parts inside that have become slick. This is a simple repair for any shop. The mechanisms are Samsung ones if I remember correctly. Expect a parts cost between $20-$40. Add in the local labor rate for the total cost. This is worth the repair cost as any replacement would not last anywhere near as long. This is also a normal occurrance as rubber parts harden with age. I have repaired many of these over the years.
Dan
Jan 05, 2009 | GoVideo Go Video DVD/VCR Combo
Tape stuck in VCR
With care, it is possible to retrieve the tape. VCR housings are held on only with a half-dozen screws and once those are removed, you will be able to see the transport. If the tape itself was defective (it only takes a stretch of tape with finger oils on it) then you will see it wrapped around several things with the worst of it around the drum itself.
The transport, if its control electronics has died, can be operated by hand once you have the tape free and laying loose so that you can manually eject the tape.
If you have made it that far, you will have a cassette with a long loop of tape dangling out.
On the bottom of the cassette is a hole a little larger than a pencil in diameter and you have to use something like a pencil stuck in the hole to release the brake. Once released, you can turn the takeup reel from underneath and wind the tape back into the cassette.
Unless the VCR is totally dead, I would take another cassette, one that isn't important to you, and see if that one will load while you watch the mechanism. If it loads and can be ejected afterward, then the first cassette was at fault in the jam.
DON'T touch the surface of the video head unless you clean it throughly with a soft cloth and some window cleaner afterward.
Jan 05, 2009 | RCA DRC8300N DVD Recorder/VCR
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Televison & Video Logo
634 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
