I have a Viewsonic VG2230WM model# VS11422. It has several blown capacitors on the power board an...
(More)
I have a Viewsonic VG2230WM model# VS11422. It has several blown capacitors on the power board an the mossfets show signs of overheating, but they are pretty rugged (will replace anyway). I foind a componant that seems to have overheated and shorted it's at location RT100 just behind the main power connector and fuse F101. What is it? If it is a resistor what is the resistance it should be at? (exterior discolored) Where can I get a wiring diagram? (to findout if you guys don't know)
The Menu section keepspoping . I press the menu button on the bottom right of the screen and after a...
(More)
The Menu section keepspoping . I press the menu button on the bottom right of the screen and after a few moments the menu pops back up and wont go away, ive rebooted unpluged everthing mIcan think off it wont stop coming back up and peventing me from seeing whats on the other side I havea hp w1907 widescreen
I want to connect an Envision LCD monitor to an HP computer that doesn't have a 15 pin port on the...
(More)
I want to connect an Envision LCD monitor to an HP computer that doesn't have a 15 pin port on the computer. What is my solution? All I can find on the computer is a serial port probably for a printer
