Question about Nortel Enet Routing Switch 3510-24T Incl Na Power Cord Rohs (AL1001E08E5) Transceiver
How to create vlan in nortol 3510 L3 switch
How do i create vlan in nortol switch model no 3510
  • 30 Answers
You would need to trunk the VLANS to the router and create sub
interfaces and then, create access lists applied to
the interfaces to control inter vlan communication. I hope this helps,
Router interfaces something like this, may not work on all versions of
IOS:
interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.1
description VLAN1_Servers
encapsulation dot1Q 1 native
ip address 192.168.1.1 255.255.255.0
interface FastEthernet0/0.2
description VLAN2_QA
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/0.3
description VLAN3_DEV
encapsulation dot1Q 3
ip address 192.168.3.1 255.255.255.0
interface FastEthernet0/0.4
description VLAN4_FIN
encapsulation dot1Q 4
ip address 192.168.4.1 255.255.255.0
Posted on Aug 01, 2009
How to configure cnet cgs-800
Hi, according to its manual, this is only an L2 switch, so no configuration is needed, if you want to use VLAN in example, you have to install an L3 switch.
Apr 30, 2016 | Cnet CGS-1600 16-Port Gigabit Switch - 16...
ProCurve 1800-24G (1010071458): how to create vlan's at hp 1800g24 switch...
You will have to log into the switch, select VLAN and create a VLAN.
http://h17007.www1.hp.com/us/en/support/converter/index.aspx
May 18, 2010 | HP ProCurve 1800-24G (1010071458)
Netgear FSM7352S - VLAN not connecting
Create the same VLAN on all the switches that will need this VLAN. All ports that link to another switch should have ALL VLAN's set to tagged.
This one VLAN should not have an IP address on any of your switches. This way it won't get routed by any of your users.
Apr 06, 2010 | NetGear ProSafe FSM7352S (0606449038880)...
How can i make 3 vlans without accessing each vlan port or each vlan are private or each pc onnected to each vlan are block and can't access each pc's
create a vlan and add a port into that vlan and connect a pc into that vlan
do the same for all 3 pcs making sure that the same vlan id is never used
Jul 17, 2009 | Computers & Internet
I need to use the switch ports (WIC-4ESW) with my 1711 router it has 1 real lrouted Fast Ethernet and a 4 port 10/100 switch tht is only L@, someone how i have to make VLANS or virtual interfaces, if...
to make a VLAN you would need to log on to the router, get to config mode, and then type vlan [vlan number] name [text name for vlan] and press enter. This creates the vlan in the vlan database (vlan.dat in flash).
Once you have done this, create the actual vlan interface by typing int vlan x and pressing enter, and then configure this like a normal interface with an ip address, etc (don't forget to no shut the interface!).
You can then either assign the vlan to the interface by going to the interface with int [interface name and number] and pressing enter, then use the switchport mode access command to set it to an access port, and then switchport access vlan x to set the access to the relevant vlan.
Of course, substitute the x's in my examples for the relevant vlan numbers.
Hope that this is of some help.
Jun 13, 2009 | Cisco 1711 Security Access Router...
Routing vlans on 3com switch 4500
i can't set ip address over 4 vlans. the 3com switch 4500 always give error message "there's not enough routing resources available".please help....
Oct 28, 2008 | 3Com 4500 24-Port Ethernet Switch
Two different subnet in same vlan how to creat HSRP
You can only create HSRP within the same domain or per vlan .For instance for vlan 20 the config will be as follows:
Primary side
interface vlan 20
ip address 192.168.1.1 255.255.255.0 secondary
ip address 192.168.2.1 255.255.252.0
standby 1 ip 192.168.1.2
standby 1 priority 105
standby 1 track[ interface name]
standby 1 preempt
standby 2 ip 192.168.2.2
standby 2 priority 105
standby 2 track ( put the the outgoing interface which this group will check incase it goes down i.e wan interface)
Backup configuration
interface vlan 20
ip address 192.168.1.3 255.255.255.0 secondary
ip address 192.168.2.3 255.255.252.0
standby 1 preempt
standby 2 preempt
NB Make sure that your LAN devices have their gateway pointing to HSRP IP but not the physical interface for example for group 1 the HSRP IP will be 192.168.1.2.Do the same for vlan 50
Nov 20, 2007 | Cisco Catalyst 4006 Chassis ( 4006)
Inter Vlan routing
Just For InterVLAN routing, Mark (enable) administration Access for ALL VLAN :P
Sep 18, 2007 | Computers & Internet
Nortel Enet Routing Switch 3510-24T Incl Na Power Cord Rohs (AL1001E08E5) Transceiver Logo
510 people viewed this question
Top Nortel Computers & Internet Experts
Jax Planet
Jax Planet
kwiz
Level 1 Expert
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
