Question about Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver
The control pod for a 3 piece speaker system's LED light is red. can you tell me what to do to get it green?
    Master:
    Sergeant:
  • 462 Answers
Not sure if it can turn to green light necessarily, try connecting a mp3 player to chk for speakers functionability.Is that what u need, its working.
Thankyou
Appreciate a good rating from you.
Posted on Aug 01, 2009
Control pod failure on bose companion speakers , the sound stops
check your wiring connections, sounds like you may have intermittent connection somewhere, and this is the most likely culprit. be certain that all connections are solid. multi pin plugs are notorious for having one bad pin.
Mar 06, 2015 | Bose Companion 5 Multimedia Speaker System...
Bose Companion 3 Series 2 Multimedia doesn't work.
Maybe a tranformer burnout, this is the most common cause, refer to a Bose service center
Jun 15, 2014 | Bose Companion 3 Series II Multimedia...
Change main fuse but still not working right
First of all, nothing wrong with the fuse. A fuse is nothing but a short piece of wire with a resistance value. If the unit turns on, fuse is fine. The fact that the headphones you plugged in are working tells you that the music is finding it's way up to that point. You must realize that the speakers themselves have additional circuitry that the headphones don't use. If you could obtain a diagram for the circuitry you might find that a capacitor or a diode or a transistor got "zapped" when the high voltage was applied.
If you have this diagram and you don't know what component is defective, can you post that diagram and I would be glad to help!
Mar 02, 2014 | Bose Audio Players & Recorders
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
Jan 29, 2009 | Bose Companion 3 Computer Speakers
Control pod on bose companion 3
try to check the circuit board with an expert
Nov 16, 2008 | Bose Companion 3 Computer Speakers
Companion 3 problem
It is not the pod that isn't working, a 220v power supply would overload the circuitry in the subwoofer. And since the damage is done, a step down converter would be no help at this point. I would take it to a electronic repair shop and have them take a look at it.
Aug 11, 2008 | Bose Companion 3 Computer Speakers
Audio control pod
I have a similar issue too, but my problem is that the sub has green light, and my control pod has an 'off' light, but it won't turn on :(
Jun 16, 2008 | Creative Labs Gigaworks S750 Computer...
Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver Logo
481 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
