Question about GE JRS04 Electric Single Oven
GE JRS04BOW3BB Will not turn on.
I have a GE JRS04BOW3BB single door oven which will not turn on (heat up). All of the buttons on the front of the control panel seem to work except for the time button. Once I select Bake setting and select the Temp, I select Start. The oven just sits there with 100 degrees displayed on the control panel. The elements do not heat up at all. Any ideas? Is there any way to have it do a self diagnostics?
  • 1 more comment
  • dtrandle Nov 25, 2007
    This did not work. I can hear the relay click when I press broil or bake, the elements just do not come on. I have tested the elements and they check out. Any other ideas? Is there a way to test the control board? Could the timer have any thing to do with the unit not heating. All of the buttons appear to do something when pressed except the time button.
    The control panel has power at the terminals when tested. Is there a way to test the themrostat? I saw two items on the back of the oven. One which is about as round as a quarter and the other is a tube that ran through the back of the stove to the inside. The one that was about the size of a quarter looked to me more like a thermal overload or a temp overload. It was in line with the power coming in to the heating elements. The other was a tube that went back to the control panel. Any additional ideas?
  • Anonymous Mar 26, 2014
    When turning the bake/broiler setting, the display only shows for a couple of seconds. The bake/broiler relay on clicks on for only a couple of seconds. The oven does not heat up.
  • 213 Answers
Turn the broil on high by itself wait a couple min. and see if it comes on. if it does the your bake element needs to be replaced or you may just have a burned wire where the bake element plugs in. just remember to turn the breaker off to the oven before trying to pull out the element
Posted on Nov 25, 2007
  • chris hooper Nov 25, 2007
    the time button doesnt have anything to do with the element coming on. what you can do , and you need to be careful because you need the power on to do this, drop the control panel and you should see a wire diagram behind it. it you look at te control board youll see the relays. relays are marked bake and broil. remove the wires to the bake relay first then set oven to bake. youll hear the relay click but you need to teat to see if there is power at the terminals after the click. just because they click doesnt mean power is going through. if know power, replace oven control. if you have power youll need to pull the oven out. look for a thermostat the size of a quarter on the back or sometimes on top of the oven if that thermostat goes bad the oven cant heat either.
    the one thats the size of a quarter is the one im talking about. you can pull the wires off a check it just like you did the elements.
Oven light stays on all the time even when oven off.
Does your oven have a switch on the front panel for "oven light" or "light" ? If so, pushing it may turn the light on and off. Also, there may be a pushbutton on the oven's front edge where the door fits. The button comes out when the door is open and turns the light on. If you have one of those, the switch could be broken or defective. If the button is missing or damaged, it could leave the light on all the time.
Mar 22, 2014 | GE Monogram® ZET1PLSS Dual Single Oven
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    My GE Profile Advantium Microwave Oven runs (and heats) continuously. The only way to stop it from running is to open the door.
    Sounds like a defective door interlock switch or a broken switch mount. If it's not a problem with the door switch or door switch mount you will need to replace the magnetron and the touch pad as well.This will fix your issue.
    Please get back to us if you have further query else please accept the suggestion.
    Thank you for contacting
    Jul 27, 2011 | GE SCB2001FSS Advantium Electric Single...
    How do we unlock the oven door! Accidentally pushed a button in front. We have no manual or SS#. Oven was in house when we bought it. We unplugged it to turn off and was able to open the door. Please...
    IF you can locate the model number tag (bottom left of door opening) you can look up the manual at
    The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can un-lock (safety feature).
    Good luck with this!!
    Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
    My GE Oven says "DOOR LOCKED", but my door does not lock. How can I get around this. Model No:JRS04BOW3BB
    Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
    Also check out this tip...
    Apr 17, 2010 | GE JKS05 Electric Single Oven
    F7 displays on control panel????? JRS04BOW3BB. Used very little. Timer kept beeping on its own so I disconnected at breaker.
    Well, F7 error code occures due to
    A = Function pad button stuck or
    B = Bad clock Unstick button or
    Replace Electronic Range Control (ERC)
    Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
    REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
    Good Luck!!
    Jul 28, 2009 | GE JRS04 Electric Single Oven
    GE True Temp Profile Oven, Locked Door Light stuck on
    there should be some type of button that the door hits to turn it on and off
    Mar 24, 2009 | GE Profile JTP18 Electric Single Oven
    GE: E Profile Single Electric Oven Model: JSP40W0WJWW
    First press and hold the cancel/off button for 10 seconds.
    If that does not work you have a bad thermal switch due to excessive heat buildup. Possibly a bad fan motor.
    The 2 thermal switches are located on top of the oven behind the control panel.
    Mar 18, 2009 | GE Profile JTP18 Electric Single Oven
    Error message...
    The F7 is intended to indicate a stuck START key. However, a design defect may cause a false indication. This can be corrected by adding insulation to the ribbon cable. You can find detailed instructions at my web site. Follow this link:
    All of the above must be entered as the address on the same line.
    I have now shared my solution with over 1350 folks and most report success. It is simple and free. Please let me know if it works for you too. You can contact me
    Nov 01, 2007 | GE JRS04 Electric Single Oven
    This would most likely caused by a door switch. It is either not being activated by the door not closing tight enough or the switch itself has failed
    Jul 10, 2007 | GE Profile JTP95 Electric Single Oven
    GE JRS04 Electric Single Oven Logo
    598 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
