Question about HP LaserJet 3600n Printer
After removing a test page the printer HP5550 shows 59.C0
I had not even started the service but the error just came like that.
  • 40 Answers
Check RAM
Posted on Aug 01, 2009
Printer 5550 laser color cood 59.c0
I am assuming you meant HP Color LaserJet 5550 Error Code 59.c0
Description
A printer motor error has occurred. This message might also appear if the ETB is missing or incorrectly installed. Ensure that the ETB is installed correctly.
Action
  1. Press the green (Select) button to continue.
  2. Turn the printer off, and then turn the printer on.
  3. If the error message returns, turn the printer off.
  4. Perform a cold reset.
    1. Turn the printer on.
    2. Watch the control panel.
    3. When the memory starts counting, press and hold the green (Select) button.
    4. Continue holding the green (Select) button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    5. Release the check button when the Ready, Data, and Attention light are on steady. The control panel will display SELECT LANGUAGE.
    6. Press (Down Arrow) button once. The control panel will display COLD RESET.
    7. Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
  5. If this message persists, contact an HP-authorized service or support provider.
Sep 06, 2016 | Laser Office Equipment & Supplies
Error59.c0
Per my service manual for this printer, the 59.C0 error states:
The product has experienced a developer motor error.
Recommended action:
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. Turn on the power and wait for the product to initialize.
If the error persists, replace the developer motor.
If the error persists, replace the DC controller
Apr 08, 2014 | HP Laserjet CM2320nf All-In-One Color...
Its displaying an error code 59.c0 how can i solve this?
Error 59,c0: The developer-disengagement motor
experienced a rotational error.
1. Perform the Alienation Motor test in the
Component Tests menu in the
Troubleshooting menu. Verify that the
cartridges are being correctly alienated.
2. Check the following connectors: J25 at
the motor (M10), J261 and J251 on the
high voltage power supply-D PCA, and
connectors J138 and J106 on the DC
controller PCA.
3. Perform the Manual Sensor Test and
observe item G. The normal state is "0".
Locate the in-line connector J70 in the
cable that is connected to developinghome-
position sensor (SR11). To find
this connector, remove the left-side
cover and look in the area below the
support plate. Disconnect the in-line
connector. The state of item G should
change to "1".
4. If the motor is defective, replace motor
M10. If the sensor is defective, replace
the main-drive assembly
Apr 01, 2014 | HP CP3525N Color LaserJet Printer
Display showing error 59.C0 on Hp Colour lasejet 3600 printer
59.C0 ERROR
An error occurred with the developing separation-drive assembly.
1.Check that the following connectors on the driver PCA are seated correctly: J403, J405, J213.
2.Check that connector J1020 on the DC controller is seated correctly.
3.Check that connector J5008 on the fuser motor is seated correctly.
4.Replace the developing separation-drive assembly.
5.Replace the memory-controller PCA.
6.Replace the fuser.
Jul 11, 2011 | HP LaserJet 3600n Printer
My Hp colorlaserjet 37ooDN is showing the error : 59.C0 Pl. HELP
59.C0 Error Displayed on Control Panel Remove all the print cartridges from the printer so the right swing guide will be visible and check for the parts described in the photos below.
If the right side swing guide does not go all the way back, the 59.C0 alienation error will be displayed on the control panel. A plastic part on the swing guide could be missing.
See photo below where the three circles are on the right side of the printer.
Figure 1: Right swing arm assembly
37001See photo for details of the part. Call-out 1 in the photo below shows the parts in place, while Call-out 2 shows the missing part. (The part looks like an upside-down t.)
Figure 2: Missing part causing 59.C0 error
370021 - Part in place
2 - Part missing
Another cause for a 59.C0 error can be the black sliding lock is broken, out of place, or missing the spring. (See figure below) This can cause 59.C0 errors or 10.92.XX errors.
Figure 3: Right swing frame assembly
37003Replace the swing guide. Please look for the missing part in the printer so it will not cause other issues from movement to other parts of the printer.
If the part in the call-out is present, close the door slowly and observe the right side swing arm. It should close uniformally with the left side swing arm. If not, arrange for service on the printer and replace the right swing arm.
Jun 20, 2011 | HP LaserJet 3700dn Printer
Error 59 co in 5550DN
Hello thanks for using fixya
59 C0 error code usually affects the printer motor. The problem can range from a couple of issues that occur within the printer's motor. It can also be a cartridge issue. Depending on the printer and which manual the user is referring to, the solution to fix this error varies.
  1. Error code 59 C0 due to problems with printer motor
  2. Error code 59 C0 due to problems with cartridges
  3. Error code 59 C0 due to broken back sliding lock
Error code 59 C0 due to problems with printer motor:
This is referred to as "developing disengaging motor rotation error" Most likely, this problem points to an issue with the function of the DC controller either it has failed or it has affected the developing disengaging assembly.The solution is quite simple and you may fix the error in a matter of few steps.
The first step is to reconnect the J16 connectors that are used for the developing disengaging motor to the J1100 connectors that are used for the DC controller PCB (that is the printer circuit board of the DC controller).After connecting these two connectors to each other,you must replace the developing disengaging drive assembly directly.The final step is to replace the DC controller PCB, after which the printer is to be recalibrated.
Error code 59 C0 due to problems with cartridges:
Another more complex problem that leads to the 59 C0 error code is a problem with the cartridges.You must first remove all the printer cartridges in order to view the right swing guide. Once these have been removed, you must check for certain parts in the printer, which mostly resemble upside-down. If you finds that the swing guide does not move all the way backwards,then the most likely problem is a missing plastic component of the swing guide. This part also resembles an upside-down T.
Another problem that may cause the error to display is when the black sliding lock is broken out of place or missing its spring. If any of these cases, you must replace the swing guide completely. You should attempt to locate the missing piece within the printer so that it does not cause further problems in it. If the swing guide does function properly, then gently close the door, paying close attention to the right side of the printer's swing arm.If the right side swing arm closes in the same manner as the left side swing arm, then your printer is functioning just fine and you may simply need to turn it off to fix the error.If the right swing arm does not close properly, then the machine should be serviced by a professional to fix the problem.
I hope this solution will helpful 4 u
Please keep thumbs up in do Rating if it is helpful
THANKS & Keep Using fixya
Jan 10, 2011 | HP LaserJet 5550DN Printer
Laserjet 3700 got 59.C0 error
Figure 1: Right swing arm assemblye755e62.png
6349049.gif 1 - Part in place
2 - Part missing
i think it solves your problem
if you have any problem regarding this issue leave a feed back,we will glad to assist you
good luck
Sep 10, 2009 | HP LaserJet 3700dn Printer
Error message call service 0150:0000000. what does this mean
error message is 59.c0 , the printer can not print any paper
and you make sound very large
May 28, 2008 | Office Equipment & Supplies
HP LaserJet 3600n Printer Logo
118 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
