Question about Dell Inspiron 1525 Notebook
Inspiron 1520 Power Fault?
18 month old Inspiron 1520 will not boot - no signs of life on the display or on any of the Laptop LEDs. No history that anybody's owning up to.
Pressing the test button on the battery pack indicates battery fully charged (all five LEDs on the pack light).
The LED on the AC adaptor goes out the instant the jack is plugged into the computer (whether the battery is fitted or not) and stays out until the adaptor is unplugged from the computer and the AC supply is cycled off and on.
The AC adaptor works OK on another laptop.
Any ideas?
A.
    Master:
  • 404 Answers
Dead motherboard, highly likely to be fine if the battery is full
Posted on Aug 01, 2009
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
I forget my MY dell inspiron 1520 Laptop of vista basic OS's password and later on typing wrong password it also blcok the system and displays messag
Crack Dell Laptop Password
U can search the above words via search engine and get ideal suggestion from search results!
Then, there will be solutions supported:
Step 1. Access other PC which isn't locked, download the Windows Password Recovery Tool 3.0, install and run it.
Step 2. Burn a password reset disk. You can choose CD/DVD or USB.
Step 3. Connect the nearly created disk with the locked Dell laptop, config bios setting to make sure it boot from the password reset disk, reboot the computer.
Step 4. Choose the user that you forgot its password, click "reset" button to begin crack its password.
Step 5. A message box will pop up, just click "Yes", then the user's password will be cracked to blank.
Step 6. Disconnect the password reset disk, and restart Dell laptop. You will login Windows with a blank password.
Hope it helps you!
Nov 21, 2011 | Dell Inspiron 1520 Motherboard
Dell Inspiron 1520 laptop will not power on. The power light illuminates for a few seconds then goes off. Nothing starts up, nothing is seen on the screen. I have removed the HDD and checked it on...
The only for sure way to check really, is to replace each part, one at a time with a known good part. Or an obvious sign like beep codes. And yes, I have noticed the older dells tend to toast motherboards. Could be something to do with power as well, though. Might want to check into that first
Jul 25, 2011 | Dell Inspiron 1520 Motherboard
Dell Inspiron 1520 laptop screen does not light up
In Safe mode drivers, in your case the video one, aren't loaded. Uninstall the one that you have now. If it's the same then probably it's a hardware problem. To be sure boot from a Linux Live-CD like http://www.pclinuxos.com/  and press the Escape key - this way you will see the boot-log in real time, look for error messages.
Oct 28, 2009 | Dell Computers & Internet
My screen on my dell inspiron 1520 has gone black
You've lost your desktop display.
The first thing I would do is to start the computer in safe mode. Once there, do a system restore back to the time that it worked.
I would also, just to be safe, do your disk management tasks like checking your hard drive for errors and running defrag.
Oct 22, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 1520 laptop. Blue Screen
Dear, Requested data was not in memory. An invalid system memory address was referenced. Defective memory (including main memory, L2 RAM cache, video RAM) or incompatible software (including remote control and antivirus software) might cause this Stop message, as may other hardware problems. What you can do is if you have more than one memory modules, you can boot the system with single and see. If this is due to memory leakage issue, you can find it here
Oct 16, 2009 | Dell Inspiron 1520 Motherboard
Dell inspiron 1520 laptop computer screen goes dark when plugged into power supply,not sure if it is due to power issues or computer itself, the screen had started to go darker on one side before i...
Check your display settings in the Power save part of Control Panel. You can set a brightness for battery and AC. Normally you set it brighter on AC and dimmer on battery (to save battery life) but if you've adjusted it for some reason that would explain it
Aug 21, 2009 | Dell V305w All-In-One R840635AU InkJet...
I have a dell inspiron 1520 that is 15 months old doesn't go on
Generally, if the AC adapter for the system's LED goes out when connected to the system, check the battery and see if it is holding a a charge (Press the button next to the LEDs on the battery see if all 5 light up)  If the battery still has power, then most likely there is a failure of the motherboard.
If you can, try another Dell D-series AC adapter and see if the same thing occurs.  If the system powers on, replace the AC adapter, if not it is a motherboard.
May 19, 2009 | Dell Computers & Internet
I need hlep please
This will fix your autoplay:
http://www.microsoft.com/downloads/details.aspx?FamilyID=c680a7b6-e8fa-45c4-a171-1b389cfacdad&displaylang=en
Activity light displays the hard drive activity, which means autoindexing is working.Also, the disk may need defragging.
Which will also make the laptop boot longer.
Dec 21, 2007 | IBM ThinkPad R40 2722 Notebook
Dell Inspiron 1525 Notebook Logo
341 people viewed this question
Alun Cox
