Question about Gateway Computers & Internet
F8 does not work to go into safe mode on Gateway desk top dx4870. Can only enter in bios. Computer says select boot only. tried changing boot in bios but it still will not turn on.
  • Gateway Master
  • 1,619 Answers
Posted on Apr 30, 2018
SOURCE:
SOURCE: Presairo V5000 notebook will not boot
Try this, get a boot able CD copy of RIPLINUX 6.2 nonX. Go into your Compact bios and select CDROM as the first boot device. Open cd dvd player and install 6.2 Power down and then power up to 6.2 Install GRUB and select HARD DRIVE Partition #2 from the menu and wait.
Now here is what will happen. GRUB will load and execute drive partition #2 which contains the original factory install for your Compact V5000T. Warning!!!! You will lose any customized programs that where added after you bought your computer (goes back to factory default operating system) by reformatting #1 partition. There are utilities that can retrive the contents of a formatted partition, but this is beyond the limits of this topic. Use Google to search for those utilities. They are sometimes free.
Posted on Feb 26, 2009
dcolvard
  • 65 Answers
SOURCE: How to remove BIOS memory cache
Since it is a Toshiba Tecra if you are not worried about losing data on the laptop you can try turning on the laptop and start pressing the zero key. It should give you the option to restore your laptop if you haven't deleted the restore partition on the laptop.
Posted on Mar 20, 2009
efs_perpends
  • 1996 Answers
SOURCE: computer not booting in safe mode
I'm pretty sure IBM Lenovo online support has a troubleshooting page to help you with your restart problem, but if you've looked there already, try to work through this article. Also see here for info on how to disable the restart and use a stop error code to diagnose the cause. Frequently this indicates a hardware or device conflict of some kind, but can also be a symptom of malware. In the latter case, I recommend you follow these malware removal protocols.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jun 08, 2009
gherna1
  • 190 Answers
SOURCE: dell optiplex 760 won't go into safe mode
It sounds as though your PF keys are disabled by the BIOS settings. Try this:
Upon cold start or reboot get to the BIOS setup. You may have to press F2 or delete, or whatever key the first POST messages instruct you to use. Different BIOS manufacturers use different keys, and you have to be quick to interrupt the boot process using the correct key. If you fail to determine what key it is, reboot once again, until you see/read what key does the job.
Next, once you're into the setup screens, look for a section where you can set/deny access to the F8, F9, F10 etc keys during the boot process.
Make sure you ENABLE them, following the instructions on what keys to use to set/reset these choices. Make sure you SAVE AND EXIT.
On the next reboot, upon the disappearance of all POST messages, make sure you press the F8 key repeatedly until you see your OS boot options menu, among which you'll find Safe Mode.
Posted on Aug 24, 2009
Solid-PC
  • 54 Answers
SOURCE: How to booting safe mode in HP DL360 G3 server
As soon as the server turns on and you see a BIOS screen press the F8 key constantly. This should be you to the safe mode screen. If not then try another keyboard, or another USB slot.
Posted on Nov 12, 2009
Gateway W35044LB
  1. Turn on the computer.
  2. After the Gateway BIOS logo appears, repeatedly press the F8 key. The Advanced Boot Options menu opens. If it doesn't the motherboard is most likely bad).
  3. On the Advanced Boot Options screen, use the arrow keys to select Last Known Good Configuration (advanced), and then press the ENTER key.
If that does not work, turn PC off, Do this again, but this time choose 'repair your computer' at the top.
If it still does not work, either your hard drive went bad or Windows is corrupt. Either way Windows must be re-installed.
Feb 01, 2014 | Gateway Computers & Internet
How to bypass password for bios
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. select safe mode with command prompt Then type at the C:\> prompt: type
DEBUG
and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type:
o 71 ff
and hit Enter. Finally type:
Quit
and hit Enter one last time to quit DEBUG back to the C:\> prompt.
Now you're ready to reboot your PC, and press the appropriate key or key
combo (look it up in your motherboard manual if you don't know it) to access
your BIOS Setup. Youll notice the password is gone. If this fails try typing At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password - works 9.9 times out of ten
If this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password http://www.tech-faq.com/reset-bios-password.html At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410 http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. Hope this helps.
Dec 14, 2012 | Gateway Computers & Internet
I can't get past the initial login screen for my Gateway dx4870. when i enter the password it says incorrect password
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
hope this helps
Jul 16, 2012 | Gateway DX Computers & Internet
Yes i lost my password and amid. word can't log in period too desk top.
Resetting password: username and password b> *Start your computer
*Keep pressing "F8" as the computer starts.
*This will enter the computer in Safe Mode.
*(When the window "Advanced Boot Options" opens, choose "SafeMode" with arrow key and confirmby pressing the Enter key, then computer enters Safe Mode.
*Once you are in the Safe mode Click "Administrator" on the Windowslogin screen.
*Take note that you have set the Administrator password before, you need toinput the changed password instead of leaving "Password" field blank.
*Then click Start > Control Panel > User Accounts > Select the accountthat is locked and change the password.
**Restart computer and login into the account you just created using your newpassword.
Sep 15, 2011 | Compaq Computers & Internet
When I turn my laptop on the desk top with the start button and other icons together with material I have saved on my desk top are not shown. The screen is blank and black
reboot it in safe mode and if it shows desktop restart once again
booting in safemode hold F8 while restarting your machine choose start window in safe mode and hit enter
best of luck
if problem wont solve let me know please i will tell you another way
Aug 19, 2011 | Computers & Internet
How do i get into the safemode on the gateway 7405gx laptop
For any windows computer its always F8.
But some times there are few boards which are designed to launch Device Boot Menu when you press F8. If you are struck with this kind of screen,
Then Choose the Hard Drive from the List then Press Enter and immediately start tapping F8 you should get the advanced boot menu now. Make you choose the Hard Drive from the list then press enter then immd start tapping F8. That's it
Feb 04, 2011 | Computers & Internet
My gateway notebook is locked n I can't remember my user password ..help very frustrated ...I tried ctrl alt del twice to make the admin acct pop up but nothing
Try booting in safe mode.
Restart your computer.
As the computer restarts, begin pressing the F8 key after the Gateway BIOS logo appears until the Windows Advanced Options Menu screen appears.
On the Windows Advanced Options Menu screen, use the arrow keys to select Safe Mode, and then press the ENTER key.
After logging on to Windows XP Safe mode, in the Desktop dialog box, click Yes.
Good luck, post back if this helps.
Jan 28, 2011 | Gateway Computers & Internet
My sony vaio VGN-CS22GH laptop shuts doen by itself randomly. Please help
The issue may be due to any recent hardwrae or software changes and also due to any virus.
1. Remove any recently added hardware/software.
2. Try to boot the computer in safe mode. Press F8 button soon after restarting the computer to enter the advance boot option and select safe mode to boot computer in safe mode.
3. If issue persists even in safe mode, perform a system restore to an earlier time or date when the computer was working as expected. Performing system restore will not delete any data from the computer.
4. Reset BIOS to default values. (Press the F2 key after restarting the computer to enter and access BIOS).
5. Press F3 and F4 keys to reset the BIOS. or press the right arrow key until you reach the exit menu, then select the load BIOS default option.
6. Then, select the Yes option when promted, save the settings and select yes option. restart computer and check.
7. If still persists, perform a system recovery using the VAIO Care Software or the F10 recovery partition.
Note: ensure to backup any important data before perfoming system recovery. System recovery will erase all the data presnt in the computer.
Nov 07, 2010 | Sony VAIO Notebook
I am getting same issue is this resolved?
Press F8 as the computer boots up, when you get a Windows menu option select LAST KNOWN GOOD CONFIGURATION and then press ENTER.
If that doesn't work boot up and press F8 and select SAFE MODE and press ENTER.
Aug 27, 2009 | Gateway 7330GZ Notebook
After booting process done. Screen goes blank and Keyboard not working only Mouse cursor is dispaly and working on the blank screen in My acer Laptop.
Try booting the system to Safe mode.
To boot to safe mode:
Restart the computer. As soon as the BIOS has finished loading, F8 key on your keyboard. When Windows Options menu appears, scroll to select the Safe mode menu item, and then press Enter.
Select "Last known good configuration" then press Enter.
If that doesn't work reboot again and keep tapping on F8 to Safe Mode and instead of selecting "last known good configuration" select "Repair Your Computer"
Or you can try this:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
  1. Place your Windows XP set up disk in your CD drive.
  2. Turn off your computer and change your BOOT order to boot from CDs first.
  3. Turn your computer back on.
  4. Press any key on your keyboard when it asks you to.
  5. Press enter when you see a blue screen, one of the options should say, "To setup Windows XP now, press ENTER.".
  6. Press enter to start the windows set up.
  7. Accept the Licence and Agreement and confirm that the setup is searching for current versions on XP.
  8. Press "R" when the set up has found your current version of XP.
  9. Notice that the Set up is deleting all your windows xp files and replacing them. (This will not cause loss of data)
Jan 11, 2009 | Acer Aspire 5610 Notebook
Computers & Internet Logo
268 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
